Wheel stud conversion
Any race shop should be able to get them or you can probably contact BBS mortorsports yourself.
Wheel Enhancement can get them for you. I was going to buy some from them until I learned they wouldn't work with my street wheels.
Once I get a trailer and sell the street wheels, I will be getting them as well.
That's one thing to watch for. Studs come in different lengths and usually have a blank area (no threads) next to the hub. If you get longer studs to work with thick magnesium or aluminum racing wheels the blank area may be too long for your street wheels. (I wonder if that made any sense)
....that what she said.
Ruf does have them, but @ $300.00 + shipping. Guess I'll have go that route.
Only consolation is that they only use the best (IMO).........
Thanks to all
As has been pointed out you need to make sure that the collar sits in the right location on the stud as they are NOT all the same and don't all work with the same wheels (pay attention to shank length). The CDOC catalog has several to choose from but the ones I wanted (bullet tip) for my car would work with either of my wheels (BBS Motorsport wheels and Fikse Profil 13's). You can easily run into a situation where the threads end and the nut needs to go a bit further. I would definitely consult a professional for this one. My race shop installed mine. I went with the BBS studs and they fit my BBS and Fikse wheels as well as my stock wheels.
FYI....the BBS studs I went with are the 65mm length stud 14x1.5mm (they are on p102 of the new CDOC catalog).
