Bad smell in the A/C - and a question
I began to have a musty smell in the car when using the A/C this season, so i bought a can of Wurth "odor remover " from Autogeek. Decided to spray into the air intake where the carbon filter is under the hood, and low and behold, there is a pool of stagnant water and debris plugging the drainage holes on either side of the battery. Washed this area and flushed the drain holes - odor gone
Question - after i removed the plastic covers, i found a 1/4 inch clear plastic hose that was disconnected, running along side of the A/C pipe to the left of the battery, just in front of the carbon filter.
Does anyone know where it goes?
Range Master
Pepsie Lite
Pepsie Lite
