I have a related question. I just learned that the IMS "failed" on my 2000 C4 with about 50k miles. The IMS nut was indeed sheared off in the bellhousing. The car was still driving, however. At the shop, the tech showed me that there were metal flecks in the oil filter. I have an aftermarket warranty that may try to have the engine rebuilt as opposed to replaced depending on cost and degree of damage to the engine. The question I have is what the metal flecks in the oil filter likely mean about the nature and extent of damage to the engine and whether it is even possible to rebuild a 996 engine in this situation as opposed to replacing it.
We have a 2000 996 with #7 main bearing damaged but crank surface good. #6 rod bearing is gone with some heat cracks on the journal. Has anyone welded up the crank and reground and hardened them with success. Customer is sick of pouring money in it. Not to interested in buying new crank and haven't found a used one yet.
Jake Raby's company, Flat Six Innovations, holds M96 engine rebuilding classes from time to time. I believe they're about $1000-$1200, plus your travel costs. Given his reputation for building rock-solid M96s, that would be money well-spent if I were to tackle an M96 rebuild for the first time. I considered doing just that (I, too, am a decades-long gearhead and do all my own work). But after adding up parts and cost for machine work, etc., I decided to have Flat Six do the rebuild.
Of course that cost substantially more, and everyone's budget vs. time is different. There are some things they're able to do (port/polish using a flow bench, dynamic balance of rotating assembly, and so on) that I can't. Back to your question, though, I would check out their class and schedule. On a Porsche engine, not hard to mess up $1000 worth trying to totally DIY...
The man is only asking a simple question that no one has answered yet.
The questions were, "Has anyone else rebuilt their own engine?" and "Would I be better off doing it myself than having it done (presumably by an expert)?"
The simple answers, I suppose, are, "Yes" and "No." The M96 ain't your daddy's big block.
This is what I was referring to since this is the only recent question that was bumped since 2008 that immediately needed an answer.
I think it's safe to say the people from 2008 already got the answers they were originally seeking.
My 3.4 crank was welded up and regrinded to a 3.6 stroke crank and then heat treated to harden the crank but we decided to use a factory 3.6 crank and crank carrier and have it balanced and cross drilled for extra oiling.
I am sure that you could have a 3.4 crank repaired the same way with success. We just did not want to use the weld/grind since we are trying to push this motor to 600+ hp. My shop actualy used it on another build that was staying naturally aspirated unlike my turbo build.
