CD Changer won't read discs
i know there are $500 adapters that will let your head unit treat your ipod as a cd changer, the issues i have are:
1) i don't have an ipod
2) if i were to spend $500 i'd get a whole new fancy head unit not just an adapter
Whereas a $5 cable is perfectly worthwhile IF the headunit will play from the CD input without a cd changer actually being attached.
Yes, for your 99 you only need the $12 cable from Becker, then switch your head unit to AUX. Renntech has a ton of DIY posts for that. That cable just gives you a 3.5mm input to use with anything that has a headphone jack. If you go to discountcarstereo.com, you will see dozens of options & prices for cables. Most any adapter that fits a Blaupunkt, will work with the Becker.
Please PM me with any interest. I forgot what my pricing was on the parts you might need, and it seems you know your part numbers well, and I don't have my part numbers yet, but perhaps I have something that will get your tunes blaring again.
Jason A. Stuart
