Need pics of taco wing adjusters
Thought to ask this group for the following:
I need pictures of the taco wing adjusting assemblies in the wing, the ones that allow the center portion to be moved up or down. If anyone has had one apart and can show how the adjusters work and how the wing asembles that would be great.
I have pictures of the adjusters on a mounted wing but can't tell how they function and/or how the wing adjusts.
By the way, the MK I aero kit has to be one of my all time favs for the 996.
Thanks in advance,
Constantine
Thanks in advance,
Constantine
I don't have pictures but I can try to describe it to you.
The wing adjustment is a right angle piece of metal with two holes on each side. One side is attached to the underside of the wing and you do not adjust that. The other side is attached to the side of the rest of the "taco", which has three sets of holes at different heights. You adjust the wing by attaching to the set of holes at the desired height.
