M96 Cylinder re-sleeving - The hunt begins
#31
Nice link, thanks.
edit: BMW used Nikasil in the cylinders in the older engines and caused some engine problems/loss of compression, etc. http://www.usautoparts.net/bmw/engines/nikasil.htm
it's not the nikasil that's a problem (it's just a low friction coating) it's the sulfur content in certain areas of America's fuel which erodes the coating over time. Common wisdom on this was that fuel derived from light sweet crude will be OK, bitter West Texas fractions will not treat you as well over time. a ton of euro 930 motors with Mahle pistons were nikasil, but from what I remember a lot of US cars were alusil (which can handle the sulfur). This was 20 years ago, and materials science may have come a long way.
Someone who needs a re-sleeve should talk to both autofarm and LN Engineering about how american sulfur content will impact he longevity of the nikasil lining. I believe that for LN Enineering to offe a lifetime guarantee they've likely figured something out.
For more information on bores and liners see wards:
http://wardsautoworld.com/ar/auto_bo...rybodys_ideas/
#32
Nice link, thanks.
#36
This is a great topic!
I have a question someone here might know:
What if I love the extra power and 8000 RPM, and want the mod done
on a perfectly working condition 2002 996 3.6l engine- would it be cheaper?
1. it would be much more fun, and 2. it would prevent the ims, rms and cracked cylinder problems.
John
John
#37
Only with luck. Crack can leak coolant into cylinder or possibly some oil/blowby....
#38
Did you contact Autofarm to see what it would take to crate/ship ...
Gents,
Upon reading the very interesting articles about upgrades to the M96 motor, I have begun a search in the US for an engine builder or tune shop that could possible offer this alternative to simply buying a new motor upon failure.
I have contacted the following shops and I am hoping for a reply:
Kinetic Speed Shop / Sunbelt engines
Farnbacher Loles
J3 Motorsport
If any other shops would be interested in discussing this, please contact me. I would like to discuss the endeavor at length to find a cost effective (vs R&R new motor) for us M96 owners.
C.
Farnbacher Loles
J3 Motorsport
C.
engine to them for the work?
Sincerely,
Macster.
#39
3.6l engines do not appear to suffer from the cracked sleeve ....
John
John
problems the 3.4l engines do.
8000 RPMs is going to be expensive to obtain.
If you have a 3.6l engine in good shape, a sleeving process with possibly an aftermarket stroker crankshaft (read $$$) could possibly bump displacement up to 4.0l with an increase in HP, say maybe a 10% increase with no other changes to the engine required.
And engine would be relatively low-stressed... 8000 RPMs could see the engine requiring rebuilds at end of every summer driving season...
Sincerely,
Macster.
#40
we went from trying to figure out how to address the reliability issue to discussing a 4.0 liter, 400hp monster engine.
guys, talk about grandiose next steps, scope creep
porsche recently announced their 3.8 with DFI and all the other fancy updates thru major R&D, mad master mind derived applications and they're still short of 400hp. what makes you guys think some podunk USA shop can top what porsche did by improving on a platform that's designed to put out 320hp, that's like 8+ yrs old? while i appreciate the christopher columbus spirit, the M96 is no mayflower of its day.
i say we focus on figuring out who in the USA can address 1) an outright failure via rebuild; 2) preventative action by replacing some parts.
but even then for the sake of full disclosure... if my reman engine fails me, i'd likely just cough up the dough to get another reman...why? warranty. you know it's put together by porsche. if i want more hp, i'll save up my dough and just get a newer porsche because it's not just about hp right? we always say this to each other.
#41
#42
For just resleeving, try Golden Eagle which specializes in the import market.
http://www.goldeneaglemfg.com/sleeving.html
#43
John
John
RE: performance goals, who knows what sort of horsepower you'll hit bored over to 4.0, but you'll need to WORK for a motor that will safely run to 8K and not ned regular rebuilds. Assuming you increased bore only you could conceivably achieve this by decreasing the reciprocating mass as much as possible: pistons, pins, conrods, and taking measures to reduce friction (polishing is it really, I don't think you want to go to silicon on pistons as well).
it's all separate:
- new sleeves
- if overbore, then overbore
- new pistons
- new pins
- new rings, seals & gaskets
- revised RMS if necessary
- revised IMS if necessary
Of course before doing all of this I'd pobably want to know whether my block was worth throwing all this work into, so x-ray or however they measure for porosity would be a step I at least would want if I was doing something like this.
Finally i you really wanted to open up the motor to bore over, I think you could do it with the existing lokasil liners as well (I have no idea how thick the liners are on a 3.6, so you may well need new sleeves but do the research!)
#44
But if you crack a cylinder wall, and the alternative is paying Porsche's new high prices, sure a re-sleeve's an economical way to get back on the road. While in there update to the latest RMS design and do your IMS work.
While you're in there, there's probably not a man on this board who could resist boring over since there's really no extra cost (you're doing new pistons an rings anyway) and you're not getting a warranty on the whole motor anyway (just the components you're dropping in). who knows how much power you can make, but with a nice set of forged pistons and an extra 400cc I bet you get more than 320, who cares, you're in there anyway. And the podunk usa shop isn't doing major engineering, just helping you with the time honored american traditition of "there's no replacement for displacement" and probably a little extra quench.
But if someone needs a re-sleeve, contact the LN Engineering people either here on rennlist or at the link i posted on page 2, see who they work with. The price they have posted is like $3800 installed with new pistons, same price for standard bore or overbore application (I'm assuming your builder will nee to actually cut your new bores, but it's worth calling to find out). The answer is right there.
