996 Forum 1999-2005
ECU Question, how often does it check for problems?
Old 04-08-2008, 03:57 PM
Macster
Macster's Avatar
Default Varies considerably. For instance if you disconnect MAF...
Originally Posted by imdrew12
Hypothetical question: Let’s say my MAF is dead or dying, and I get a cel to warn me about it. I am lazy so I unhook the battery to reset the cel. How long does it take for the ecu to perform another test to see the MAF is bad and throw another cel? Is there a set time or mileage that the ecu waits to perform another “systems check” or would it be instantaneous? How or when does the ecu know when to issue a cel for a minor issue? Just curious.
Drew
from harness CEL may not be set for minutes maybe longer if my memory of when I did htis some years ago is accurate.
Even if MAF acting up, it may not act up right after engine start. It may take time to start acting up and it may upon an engine shut down even if followed by an almost immediate engine restart may self correct, temporarily.
The ECU constantly moitors its various sensor population for problems but some and dare I say most problems aren't clear failures, but readings that drift out the normal range over time.
For instance say the engine has an air leak . At idle the air leak admits considerable air that is not measured by the MAF and the engine controller will adjust for the air leak by adding extra fuel. If this condition continues too long ECU will cross a threshold that esssentially says it has gone too far to the rich end of its adjustment range and this will cause a CEL.
However, if the idling state doesn't last long at higher engine speeds the amount of air from the leak drops to insignifiance compared to the huge amount of air being admitted by the throttle.
So the engine controller may undo its enrichen action.
And the MAF doesn't have to be the source of the problem.
Sincerely,
Macster.
Old 04-08-2008, 04:12 PM
imdrew12
imdrew12's Avatar
Sincerely,
Macster.
OK, I think I get what you said. So basically the ecu must "learn" that the maf is bad or faulty and adjust accordingly, just like the ecu will "learn" that you have installed a new intake or exhaust, and this "learning" may take some time. If I read this right then its not much different from the Subaru ecu. Depending on how you drive the WRX, you can gain or lose up to +/- 20hp after an ecu reset.
Old 04-08-2008, 04:33 PM
Tippy
Tippy's Avatar
To the OP, disconnect your MAF harness and drive around, this is what it will do and answer your question.
It takes 4 driving cycles to reset the CEL, or you can start and stop the motor 4 times and it will do the same.
Old 04-08-2008, 04:37 PM
imdrew12
imdrew12's Avatar
Thats kinda weird. Exactly 4? Good to know though. Thanks!
Old 04-08-2008, 06:52 PM
Mother
Mother's Avatar
How do you like the Durametric software? I looked at their website and it looks quite in depth. Which package did you go with?
I ordered the cheapest one which is made for porsche and is used for the private owner and not the pricer one for businesses which can be used for multiple cars . If you have some knowledge of cars then this is priceless. As then engine ages and you can save a base file and compare to later files to see how you car is doing or just use to find out that your O2 sensor and MAF are bad etc and then just replace and reset system. I have some EXCEL data sheets from the durametric at this link:
http://www.webbspot.com/Porsche/fvdvideo.html
or this thread for more on MAF workings:
https://rennlist.com/forums/showthre...percharger+fvd
Old 04-08-2008, 09:17 PM
imdrew12
imdrew12's Avatar
Thanks for the info. I remember following your thread, sorry about your engine. Any updates?
Old 04-08-2008, 11:21 PM
Mother
Mother's Avatar
Called porsche in scottsdale today and they want $10,330 for rebuilt and yet suncoast is 5K cheaper, so to say the least I was upset on the price difference between dealers. I was hoping for same cost and save on shipping charges of core and new engine. At a loss now.
Old 04-09-2008, 07:49 PM
Macster
Macster's Avatar
Default The ECU is constantly 'learning', when in closed loop mode. It constantly...
monitors inputs from a variety of sensors and from this knows the air/fuel mixture is ok the converters are working the o2 sensors are working/etc, sort of...
Unless a sensor fails outright or in such a way the failure is readily apparent, the ECU can only adapt until it succeeds or fails by going outside of its adaptability limits.
For instance if the coolant sensor is faulty, the ECU may believe the engine's colder than it really is and feed the engine a richer than normal mixture.
However, it will know by the oxygen levels in the exhaust that something's not right and possibly override the enrichening triggered by the erroneous coolant sensor input and go leaner until the O2 sensors are reading within acceptable limits.
Only if the coolant sensor reads -40 might the ECU then have to go too far towards its leaner adjustment that a CEL would be set. It might even report O2 sensor diagnostic error when in fact the coolant sensor is the real problem.
Anyhow, the ECU will know something's amiss and of course attempt to adapt.
If it is successful, no one is the wiser.
If coolant sensor so far gone, or gets worse, or varies its misbehavior (probably the most common case) the ECU will swing back and forth as it tries to compensate.
Same applies to the MAF.
The ECU has to have some room to adjust/adapt to deal with variations in engines and engine components, driving styles, climatic conditions, fuel differences, etc.
I do not know what driving cycle or cycles are required for the ECU to relearn. Maybe not much, but since the ECU must deal with a variety of operating conditions, engine speeds, cold/warm/hot starts, etc., a goodly mix of driving may be necessary.
Even more difficult is if the check engine light is extinquished and its associated error code is erased this resets all readiness monitor tests to incomplete.
These require some effort to see them all set to complete. Engine restarts are not sufficient.
For your Subie, chances are you could have gained the HP (or at least the sensation of additional HP) by making a pass or two down the quarter mile.
Generally for those that drag race modern cars, the first and sometimes 2nd pass is to give the ECU the chance to 'relearn' a new set of fueling/ignition parameters under the driving conditions (quarter mile blasts) the car is being exposed to.
(One just hopes one doesn't undo all that learning by sedate driving back to pits and lumbering around in car visiting other attendees until one's next pass is up.)
And when the car is driven from the track back home the ECU unlearns all it learned at the track and learns all it needs to learn for the street.
If you're not at the track and couple of hard acceleration runs up through the gears can suffice.
If the engine picks up more performance with a ECU reset, then somethings amiss (I would hazard a guess) which is causing it to adjust at the expense of engine performance for possibly emissions compliance or converter safety.
Sincerely,
Macster.
Old 04-09-2008, 08:31 PM
imdrew12
imdrew12's Avatar
Sincerely,
Macster.
WOW, thanks. Great explanation!
Quick Reply: ECU Question, how often does it check for problems?
