Ethanol concerns
That is hysterical.
You don't actually believe what you just stated regarding the computer reading the combustion as pre-detonation, do you? Not using ethenol based fuels in a race car is because ethanol reduces the BTU of the fuel and therefore power per volume and not because there is any change in combustion. Methenol has an even lower BTU than does ethanol. E10 fuel is perfectly safe for your car.
Sounds like the guys who work on your car were playing with you and seeing how much you would fall for.![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
That is hysterical.
You don't actually believe what you just stated regarding the computer reading the combustion as pre-detonation, do you? Not using ethenol based fuels in a race car is because ethanol reduces the BTU of the fuel and therefore power per volume and not because there is any change in combustion. Methenol has an even lower BTU than does ethanol and is not used in E10. E10 fuel is perfectly safe for your car.
Indy cars have used ethanol based fuels for years.
Here is what I believe: Timed laps. Soot in my tailpipe in a car that I ran Sunoco in for years. Changed exhausts, stopped running ethanol, clean tailpipe. An experienced Porsche racer and crew chief. Or how about the fact that Top Tier fuels use ethanol in their low and mid-grade fuels but NOT in their premium grade fuels. Why might that be, do you suppose?
Here is what I don't believe: An abusive, raving lunatic on the internet who will pick a fight over anything and has not once, ever, provided a scintilla of evidence to back up his rantings.
And, um, just guessing here, but I think Indy-car engines might just have their DMEs tuned especially for the fuel they use and the driving they do and therefore might be irrelevant (typically) to this discussion. Just a wild guess...
P.S. I'll speak slowly, here, so you can follow along... I did not say ethanol was unsafe in any car. I said that in some cars there is a performance loss.
You're right. But the octane rating number attached to gasoline grades rates its resistance to compression combustion, it doesn't quantify the amount of 'octane' in the fuel.
Sorry if I was imprecise.
And, um, just guessing here, but I think NASCAR engines might just have their DMEs tuned especially for the fuel they use and the driving they do and therefore might be irrelevant (typically) to this discussion. Just a wild guess...
Then you start arguing about something that no one disagreed with you on. I clearly stated that ethanol has a lower BTU and that is why most race cars do not use it. So WHY, the rant? Why are you talking about NASCAR?
Finally, knowing that you will be found out, you start with the personal attacks, hoping to discredit me in hope that, somehow, this will make you right. Well, sorry, you're still wrong about the "pre-detonation".
So, I ask you once again. How does an E10 fuel increase pre-detonation when scientificallyas well as in real world application, it has been proven that E10 fuel actually reduces the risk of both pre-ignition and detonation when compared to the same untreated fuel?
So, just how would E10 based fuel cause pre-detonation where regular fuel would not? Don't avoid the subject I stated was incorrect which you always do. You state one thing and then when you are corrected, you spin the subject to something else.
Another distraction from your ridiculas statement about pre-detonation maybe?
Please reread my post. I did not say it caused predetonation. (NASCAR was a mis-type, for which I apologize. I meant Indy, and it was you that brought it up, not I). Nor did I say that ethanol doesn't reduce the risk of it, in theory. What I said was that the little computer that runs your engine doesn't necessarily see it that way.
You don't read carefully. You have a chip on your shoulder the size of an Airstream trailer. You refuse to back up a word you say. Why on earth am I going to have a public debate with you about this? There is absolutely zero chance that it will be rational or productive. Instead, you will rave and mock me and prevaricate and change the frame of reference in a slippery and lame effort to look smart and try to rally the other kids in the playground around you. It's tiresome. I'm out.
So, I will rephrase my question: Which of the DME's out there would read the combustion of ethanol as pre-detonation? There is absolutely no difference in the combustion of 100% gas or E10 that would create anything that could be sensed by the DME to adjust timing on an otherwise properly running engine, except that E10 would help reduce knock if it was present with 100% gasoline of the same type.
I am interested in learning about these "some DMEs" that are somehow so intelligent that they know that there is ethanol in your fuel and determine they should retard the timing when there is no knock caused by the E10. Since a DME is designed to adjust fuel/air mixture as needed, the only reason the DME would retard timing is because the knock sensors tell them to. If your engine is not knocking with 100% gas, adding 10% ethanol to the same gas will never cause knock.
You further state: "....the phenomenon has been proven to my complete satisfaction". It must be a salesman's dream.
If you were aware of the way your car detects pre-ignition and detonation, you would realize how funny your statement is.
Now, do what you promised and stay out of this discussion.
You don't know what you're talking about, I'm afraid. Just how do you think a DME gets its information about predetonation? If you knew how a knock sensor works, and were a reasonable human being, you might be at least a little bit open to the idea that it's possible for a piezoelectric microphone to send information to the DME about other kinds of abnormal combustion besides real predetonation. Knock sensors, especially on older cars, can be easily fooled.
Contrary to what they may have told you at Hogwarts School of Auto Mechanics, your engine is not full of little tiny men in lab coats with little wee clipboards, peering into combustion chambers between power strokes.
And nobody was selling me anything on this particular day. It was just an intelligent conversation with experienced people with real qualifications, sharing something valuable they'd learned empirically about certain cars. You should try it sometime.
This behavior is typical of someone who learned about a subject by listening to others rather than first hand experience.
Rant away. I'm going elsewhere.
Ironman 140.6
[QUOTE=1999Porsche911;5235920]Not using ethenol based fuels in a race car is because ethanol reduces the BTU of the fuel and therefore power per volume and not because there is any change in combustion. Methanol has an even lower BTU than does ethanol and is not used in E10. Indy cars have used ethanol based fuels for years......as well as methanol.
[QUOTE]
+1
BTU per unit. Oh BTW, what type of oil should I use?
[QUOTE]
+1
