Traqmate, need help with RPM and others
I have the Traqmate with Traqdata: I want 3 inputs
I have a 02 996 cab.
I have found some info ... but need more
1)Were would I hook up the RPM at??? (02 c4 cab)
2) The brake, Has anybody done this, with a pressure sensor....and where did you get the sensor...I think I would learn more from the pressure???
3) if possible the TPS = Throttle Position Sensor
Thanks all
Jerry
Thanks all
Jerry
Hey Jerry,
I also just got your email.
Attached link for 996 ECU location, you can get both RPM and TPS from there.
http://www.turbo911.com/showthread.php?t=289
Also attached link for pedal position sensor for brake pressure. It's by Race Technology, so you may want to check with Traqmate whether they make the same, or if this one would work directly with your logger. (I don't see why not.)
http://www.race-technology.com/pedal...vel_8_969.html
I believe you can pick it up from the ECU, too. You can find the pin # from the shop manual or the Bentley manual.
Cheers,
Toby
Cheers,
Toby
Dell thanks for the info
RPM is done!!!!
Toby, thanks for the links,
I will call My dealer today and see if they will give me the wire info of the ECU??? as well as the placement of the unit!!!!, my cab is a little different than that turbo
Jerry
RPM is done!!!!
Jerry
