996 Forum 1999-2005
Do all C4S's have a squeaky front suspension?
Old 03-01-2008, 09:12 PM
sullivs
sullivs's Avatar
Default Do all C4S's have a squeaky front suspension?
Dear C4S owners,
I am looking to purchase an '02 C4S this spring. I just found a beautiful one that is nearly perfect, except some squeaking noises was coming from the fron at low speed. At all other speeds, the car drove straight, solid and quiet. Only at 0 to 30 mph, around the neighborhood, etc., is it noticeable. It is not very loud, and sounds like a rubber bushing-type squeak. But I know it will drive me crazy. The seller said it has always squeaked, and he said all 996's squeak. The car has 30k miles on it.
I have seen other posts here about squeaky suspension parts, and some people mentioned the lower control arm bushing. Is this a common issue? Is it very expensive, a DIY project? I have not had a chance to drive others yet, and this one is everything I'm looking for. What say you?
Thanks in advance for your advise.
Steve
Old 03-01-2008, 09:35 PM
MikeH2
MikeH2's Avatar
Obviously this is subjective, but I don't notice any squeaking from my C4S. But maybe I just am not very sensitive to it.
Good luck with the car search...
Old 03-01-2008, 10:00 PM
pongobaz
pongobaz's Avatar
nope...no squeaks on mine either. Stock suspension with 40K miles.
Old 03-01-2008, 10:04 PM
Phil G.
Phil G.'s Avatar
None - zero squeaks (except for the mice in the garage).
dresler
dresler's Avatar
no squeaks.
Old 03-01-2008, 11:33 PM
omnipresent
omnipresent's Avatar
no sqeeks
Old 03-02-2008, 12:10 AM
JBRipps
JBRipps's Avatar
no skueeks...02 c4s...47k miles.
Old 03-02-2008, 12:15 AM
Palting
Palting's Avatar
+1 to the choir. No squeaks here either.
Old 03-02-2008, 12:46 AM
Ms.Greta
Ms.Greta's Avatar
No squeeks! My 04 C4S is for sale - pm me if interested. Perfect - fully located - CPO warranty.
Old 03-02-2008, 12:58 AM
jsmirand
jsmirand's Avatar
Um, if the seller says that all $90,000+ Porsche Carrera 911's squeek from the front, then it must be true because the seller would have no incentive to lie.... :|
Old 03-02-2008, 11:44 AM
sullivs
sullivs's Avatar
It seems the consensus is to expect "No Squeaks". If it is, as the other threads have mentioned, the lower control arm bushings, anyone know if some type of rubber or plastic lube would cure it? It's curious that with only 30K miles that the bushings would be shot, or loose enough to make noise. And according to the seller, they always have.
Anyone have any experience in the lower control arm area? I would hate to pooh-pooh this car just for the squeaks. It truly is flawless in every way, and I know he has been religious about servicing the car at a local dealership that has a good reputation for taking care of us Porsche owners.
Thanks,
Steve
Old 03-02-2008, 01:14 PM
shustermeister
shustermeister's Avatar
Um - 02 C4S, 18.8k miles - no squeaks
Old 03-02-2008, 08:46 PM
demosan
demosan's Avatar
Originally Posted by sullivs
Dear C4S owners,
Steve
Steve,
No squeak here in my 02 C4S with 30K miles. Never had a squeak either. I have heard of some noise solved by tightening the sway bar mounts.
Good luck with the search!! demosan
Old 03-02-2008, 09:17 PM
Ubermensch
Ubermensch's Avatar
I had a squeek similar to what you're describing. I recently replaced the control arms with gt3 parts and I have ZERO squeeks now. Parts were about $600 and I did it myself (may not be something you want do tackle depending on experience level).
Old 03-03-2008, 08:00 PM
jumper5836
jumper5836's Avatar
I thought mine was creaky, ended up that my gas and brake pedals are creaky and not the suspension. Sometimes the dash board creaks.
Quick Reply: Do all C4S's have a squeaky front suspension?
