DIY on Bose Subwoofer Removal
Can anyone point me in the right direction on how to remove the Bose subwoofer behind the back seats to access the top of the shock mounts. I have seen a few DIY guides but none explicitly showed the proper way to remove the carpeted panel and I am afraid of breaking any clips.
Thanks!
Thanks!
1. pull out the two "Bose" plastic port enclosures
2. Use a torx driver to remove one torx screw on each port
3. slide out subwoofer
4. unclip wire to the subwoofer
www.renntech.org has pics, if needed.
Thanks!
Thanks!
things to be carefull of, don't break the weak plastic tabs that hold the "bose" trim pieces on. (I did, $25 later and they are replaced).
If you can get to the subwoofer mounting bracket screws and remove the brackets BEFORE pulling the carpet and foam back, do it first. It is hard not to tear the foam when pulling it out with the bracket in place. Same goes for putting it back, get the carpet and foam in right, then put the bracket back.
The easiest way to get the center section up is to reach behind it by hand it the center at the back (between the seats). This section actually tucks underneath the top section that goes back to the rear window. Start from the inside and work your way out and it comes up very easily (takes only a few seconds). For the out pieces, pivot them up from the inner side. The outer side is tucked underneath the side panel. The outer sections fit fairly snugly over the top rear shocks and you can tear the foam if you try to pull them out wrong. If you do happen tear it, don't be too concerned. One you put it back together, you won't be able to see it as it will be hidden beneath the carpet.
