PSM light staying on. - light off, Durametric worked
Duramatric is what I am going to use tonight. I will post up what it reads out the fault as.
so it sounds like I should test to see if ABS is working. The light is not on so I expect it to work. I can check that easy enough! I will check my brake fluid level, but I think a light would be on if that fluid was low. I downloaded the Durametric software to my laptop so I can check the car using his hardware.
I am getting a fault when I check under the ABS 5.7 /PSM tab. 4480 Unknown DTC. It will not let me clear it. when I try to clear fault memory it gives the second picture. also I cannot check the over-revs on the engine or some other stuff the software is supposed to do.
Other interesting faults:
Alarm
Current Fault Codes
25
W lead
Status: not present
Frequency counter: 1
33
Interior sensor faulty
Status: not present
Frequency counter: 5
Airbag
Current Fault Codes
3
Supply voltage
1
Airbag warning light
Engine stuff:
Motronic 7.2
Vehicle Data
Porsche part number 98661866005
Supplier part number 0261204790
Software version number: 004157029000
Number of ignitions range 1 17909 / 1781h
Number of ignitions range 2 0 / 0h
Operating hours counter 1789
VIN: WP0CB29811U665107
Type ID DME control unit _986SUS01
Order type 986320
Country code C02
Engine type 9621
Engine number
Transmission type G8620
Transmission number 0
Radio code 0
Body color/convertible top color 6B4A10
Interior equipment MC
Alarm
Current Fault Codes
25
W lead
Status: not present
33
Status: not present
Airbag
Current Fault Codes
3
Supply voltage
1
Engine stuff:
Motronic 7.2
Vehicle Data
Order type 986320
Country code C02
Engine type 9621
Engine number
Radio code 0
Based on code 4480, here is some info. May be related to your booster pump or connection. As I said above, it's been a while since I used mine, but I thought you could select the error to bring up more information.
Nice! Thanks DFC! it would not let me select the fault code although it looked like I should be able to. where do you get the PDF's of the fault codes? PET?
after hooking the unit in again and trying to reset the PSM fault it worked! I started the car and the light was off. I just got back from a test drive where I tested the PSM and it worked great. I was able to turn it on/off with the button. Everything looks great now, I hope it stays that way!
Great! Hope it's back to normal for good. The info was from the 996 Group 0 Diagnosis Part 1 (up to Repair Group 45) workshop manual.
No affiliation, http://www.cannell.co.uk/Manuals.htm
Fault code 4480
Possible cause of fault
- Short circuit to ground/B+ or open circuit
- Booster pump motor locked up/faulty
- Wiring/plug connection faulty
Have you checked to see if the fuse is blown? (fuse B9)
