X-51 oil pan install
so this is what i am talking about. i agree, it's a better seal to the case but to slow down the movement of oil a smaller area would be better than a larger area.
That area In red is not 25%,
Look were it hits, It makes a little cubby and the rubber is a better seal than the notches in the plastic that just get close to the block.....
I think Porsche did this so oil would not go with the G force... the plastic had gaps that the oil was forced through, this is a better seal not 100%,
Jerry
Jerry
Jerry
Jerry
true the baffle is to create a more controlled oiling situation when cornering. because the x51 tray seals off to the case, there is no opportunity for the oil to bypass the oil pickup area, as it does with the plastic version.
one thing i would consider doing is enlarging the holes so the oil doesn't have to climb over the tall walls. then use a bigger metal door to seal it off.
actually, if i had to do it again, i would just use the plastic version but seal off the area behind it. (just thinking out loud)
Nice thread - love the tip about buying just the windage tray for $30 - a no brainer indeed. Now, am I observing that the increase in volume is fore-aft? Certainly there would be less chance of sustained g-force in this direction compared to side to side. Or am I just confused?
Jeezus guys..like I said already in my mod thread. All of what I have done has been approved by race technicians. So much so, that my modification is being copied for fabrication by J3 Motorsports in Buford, GA.
It has been checked, measured and confirmed 2x. The issue is over and is installed in my car.
Do what you feel like in your own. Track use puts a higher amount of heat, strain and pressure on your car. My philosphy is VERY simple. A properly setup car is ALWAYS the way to go. I always ask questions to those that have the experience to answer properly. Not just a guess.
Do what you will. I will continue in the process I have begun. Next up for me? 3rd radiator with nose slots cut out on the front fascia.
C.
C.
What I will confirm is a modification to the stock baffles. Same thing is done. Removal of the rubber doors, cutting larger access holes, replacing with metal doors and expanding the width portion. My reasoning for going with the X51 was simply due to the metal. With the chemical properties and the heat involved, metal was the better choice for me.
Besides $250 is cheap in the grand scheme of parts for these cars.
C.
C.
I still recommend the metal door modifications.
C.
4 large can you give an idea of how difficult it was to remove the pan, did you have to leverage it to brake the gasket / sealant loose, if so any advice to make the job go smoothly. Also, I think B&M make a thicker gasket for the pan and the windage tray to increase volume ...
Newbies Hospitality Director
I have been researching this for a bit now. Maybe it isn't worth $250. But it is worth $30. For $250 you are simply getting the x51 baffles already bolted onto a brand new shiny oil pan that is identical to the one you already own... $170 down the drain.
Porsche has updated the baffles aka windage tray. The 997 cars came with the x51 baffles as standard. The blanket replacement windage tray (for 3.4 and 3.6 liter engines including X51) is the now same part number as used on the 997.
Part # 997.107.243.00
$30 from most of the discount places.
