Preserving codes, etc., while changing batteries
SORRY if this is repeat, but I spent a lot of time paging thru battery threads tonight, and did not see anything.
Is there any (SAFE) way to preserve the codes (ECU, radio, etc) which changing batteries? Would the battery maintainer that works thru the lighter keep the codes in order?
What codes do you need? You have an '03 so the DME saves the radio code. There is no ECU code to save so to speak. You may reset the ECU, but it will quickly learn your driving style again...
What if the question pertains to '99 - '01 cars? I was thinking the same thing myself recently.
Excellence had an excellent article recently on how to tell if your alternator and battery is healthy using the volt meter. I remember as far as the volt meter should go up to 14 volts after start up showing the alternator is healthy.
There is also another section on turning on the lights without starting the car and seeing how far the voltage goes down and what deems it a battery in weak or healthy condition.
Newbies Hospitality Director
When I recently replaced the battery in my '04, everyting worked immediately except for the radio stations I had previously programmed to the buttons.
However, give the radio some time, 5 minutes or so, to reload stations you have previously stored in the system. I began immediately to reset the stations and by the time I was finished with the 4th button, I noticed that buttons 5 - 8 were back to the original programming.
You also lose the engine monitors needed to pass a smog check (in CA). If your battery dies or is disconnected, you need to drive the car until it is damned well good and ready to let you pass smog. No one seems to be able to determine exactly how much driving of what kind is needed, either.
