Will this work?
Will this work?
Will a PSS 9 from a GT3 fit on my 99 996 C2? The part #'s are Front spring 996 343 531 95, front strut 996 343 041 95, rear spring 996 333 531 95, rear shock 996 333 055 95
Yes, a 996 GT3 stock suspension is a straight bolt on to a 996 C2 (pre- or post facelift). All you need to ensure is that you have (beside the coilovers) the front camber plates and the rear drop link mounting part + potentially all 4 droplinks if you do also change the sway bars.
Guess how I know? Did the upgrade two days ago on my C2 '00 Cab.
Thats good news that it is a straight bolt on. I just bought a complete used set for under $300, including springs, drop links, and camber plates. Life is good. Hopefully in a month or 2 I will install it.
Thanks for the info.
