when i have the top up the rear windows can be conrtrolled to go up and down. but when i have the top down, i no longer can raise them with the switches inside. i am pretty sure the buttons are fine because they work with the top up. please please help.
Little trick......When the top is down and you want to operate the rear 1/4 windows, hold in the "button" where the "hook" goes in on the top (between A pillars) and you can operate the windows!
Dell did post that trick already 1 year ago and I use it all the time to operate the rear windows with the top down - even while driving somethimes
I also have the Smartop but got it so I could have 1-touch open/close when moving.
Dell, I hate to be the one to tell you this, but you don't need a Smartop for your GT3 because it's a Coupe! You really need to learn to be more observant!
I think that Dell is referring to his 2nd line 996CAB--84S (for city cruising)........I don't to **** Dell off to much or he never comes back and helps us out!
Yah, I know he was referring to his Cab, but I like to throw a little **** his way every now and then just to keep him humble.
