So I was going through the 996 tool set and noticed it does not have the tool socket to get the wheel lug nuts off. Anyone know the part # to that so I can order one?
Newbies Hospitality Director Lifetime Rennlist Member
Are you missing the standard lug socket, or the anti-theft socket. Did you check inside the pouch that is on the inside of the fabric spare wheel cover?
Missing the standard anti-theft socket. And yeah checked the inside of the wheel well as well as the pouch. The pouch has the usuals, the screw driver, the tool to loosen the headlight assembly, the little steel bar to keep the wheel in place once mounted etc etc.
There are 30 different wheel lock keys. Guess someone used it and did not put it back in the car.
You might check the option sticker to see if someone wrote down the number. If not then take the car to a dealer and they will match it and can order you a replacement. They are made by McGard but not shown on McGard's site.
Or, have the locking wheel bolts removed and replace them with standard bolts.
Ok I may have confused all. The tool I was referring to was the normal type used to take the Non-locking wheel nuts off. Previously I had used the lug nut wrench that came with my X5 with no issues till I found out the original Porsche one is missing. Here is what I got (picture below)
Hopefully someone would know the part number for that lug nut wrench "thingy". Earlier I had meant to say the non-anti-theft socket. My mistake...(case of the Sundays)
