Interior Dome Light
Interior Dome Light
I tired the search engine but not luck... Okay so the Dome Light, i know the Left and the Right Switches are Spot Lights... but what does the "Center Switch" do? Is it sopuse to turn all teh lights on? mine seems to do nothing...
There is a center light in addition to the left and right "map lights". The center switch is a 3-way switch. 1 - center light off, 2 - center light comes on when either door is open, and 3 - center light on. If your center switch doesn't do anything then your center light buld may be burnt out.
Open it up, pull the bulb out, and hit the auto store for a replacement. Really lights up the interior nicely, makes it easier to insert the key in the right place too!
Just go easy on the over-engineered fragile plastic!
Also what is that little button thing?, its like a Reset button for Handheld Divices...
Cap'n Insane the Engorged
The L.E.D.s, the little ambient lights in your car, it adjusts how bright they are. There's one each door handle and a couple near the dome light.
Only MY01 and up have them.
Newbies Hospitality Director
But the switch in the pin hole only adjusts the brightness ot two LED's 1) the LED on the driver's door handle (which illiminates the ingition switch) and 2) the LED on the front of the dome light (closest to the windshield) which illiminates the upper center console (horse shoe switches).
How many Porsche owners does it take to change a light bulb? Six, one to ask the questions and five to debate how to do it!
Zookie, Your center light is burned out. The 1st attachemet contains the instructions on how to operate the dome lights. The 2nd attachemet shows the instructions on how change a bulb in the dome light housing.
Eurocarguy911 (03-09-2020)
