my 996 soft top is in need of some repairs. as you can see from pictures, the wire which runs on the very edge of the top snapped at the very bottom (only clip is left in place):
because of the wire not pulling on the side of the top, it does not end up sitting inside the grove properly:
it looks like i should be able to pull the old cable out and put a new one in. the questions are:
1. is this an easy DIY project? (looks like it)
2. i could not find how the wire is secured on the opposite end.
3. any special tools i might need?
rdstemler, when we use our hard tops thru the winter, the soft top must be down. I doubt that Porsche would sell the HT if leaving the top down was a problem.
what earlier posts? i searched for 'convertible top problems|cable|issue|repair" and didnt find any anything identical to my issue. want to give me some better keywords to search for??
