996 track alignment using R6
I need help with alignment settings for a JIC, lowered, gt3 sway bar equipped 996.
I've been running MPSCs; 235/19 and 305/19 at DEs recently with the following settings:
Front neg camber -2.0, toe +.13
Rear neg camber - 2.1, toe +.30
Front tires are rolling over with the correct tire pressure, according to Michelin specs. indicating more negative camber is called for. Sway bars are at full stiff rear and 1 hole from full soft at front -- Car is almost balanced but still exhibits understeer - much more so than my 964.
To compound the problem, I'm changing tires to Hoosier R6s - 235/19 and 295/19.
I need help with a starting point for the alignment. Thanks, Carlos.
