Center Console
FYI....you need to remove the entire rear center console to replace the hinge. It's impossible to do in a CAB. Their might be a little space to work with in a coupe' but I can't speak for that. Regardless, to do it properly you need to remove it.
Here is the DIY for the replacement.
That doesn't help anybody without an explanation.
I'd be curious to know how you got the brackets into the rear opening and kept them square to rivet since the rear center console sits flush against the rear tunnel.
Well... I first placed a fresh painter's canvas drop cloth across the back seats and tunnel and pulled it down into the seam between the console and the tunnel (so as protect the material and catch drilling swarf). I then removed the cover per the TSB and carefully sawed the remnants of the plastic hinge with a dozuki. I installed the little metal U-brackets with curved-tip needle-nosed pliers. This was aided by first sliding a metal putty knife down into the seam between the console and the tunnel so as to depress the carpeting on the tunnel. This created ample space to slide the brackets in. I then doubled over a plastic zip tie and temporarily slide that into the recess of the U-bracket. This served to press and hold the bracket in position while I drilled the hole for the pop rivet. Pulled the zip tie back out and the rest is per the TSB.
LVDell
Ordered today from Hendrick. They're mailing to my door in RH for delivery tomorrow, all fo $30. Can't be that for an hour of sweating
Eric, thx for the name and number.
So how many acres on your little farm I'm getting?
My farm is less than an acre so not much
Removal of the center console takes LESS than 5 minutes. So you are saying that your "prep" and "clean up" were both sub-5 minutes?
Got er done!
Completed my console hinge replacement this weekend. Took over an hour, but that's because I kept having to run back into the house to cheer Tennessee as they beat Georgia!
Anyway thanks for all the input. the DYI and pics made this an relatively simple job. I figured it added about 10 hp too
Pat
Pat
I had to remove the console, but it was pretty straight forward. Going slow not to add any more scratches, took a hour +
I found that it already had a replacement metal hinge but the rivet was popped out. I used the new clips but some sheet metal screws that went in nice and tight. Its a pleasure to have a smooth lid again !
If I win your farm...are you going to move?? Because if not you can keep the farm and all bets are off...I can't imagine living there with your annoying, commanding, professor, telling everybody what to do YOU.
I bet you can't be like that to your wife!!
I am refering to this
Newbies Hospitality Director
I sure hope that was a momentary lapse of judgment on your part b/c up until that post you just made, I thought we were cool. Guess not.
Back to my other subforums.
