X74 Track Impressions
Tried the X74 at Laguna the other week. Love the looks and for that, it's a keeper. Far less body roll, but not too impressed w/ the balance. Could be a whole raft of factors like tires, new track surface, don't know how to drive, but assuming all else equal, my car is one pushy little piggie now. I liked/needed to trail brake the stock setup and always got a little nervous about overdoing it. Not now, boy. I used to be able to throttle steer, but now all that does push the car off the line. Can't rotate into the line. It is a takeoff from another car and I wonder if I got the stock rear bar by mistake. Need to check part numbers. Front bar is easy to tell on weight alone, but couldn't tell on rear bar by heft.
Had it realigned to -1 front and -2.3 rears. Was 0/-2.1 before.
I now lift the inside front tire looking at photos. Assuming everything is right, I'm thinking I need to rebalance the car w/ different tire sizes? Too much heat on the outside fronts? Didn't have time to check temps or anything. Didn't expect perfection or anything, but I didn't think I'd go in the opposite direction. I'll drive it a few more times at the track, but any general thoughts? Might this be why Porsche doesn't recommend it on my 2001? Just kidding...
Thanks.
Thanks.
I'd play with tire pressures a bit. I don't experience any significant understeer in my car (99 C2 w/ X74). I am using the factory specs on the alignment too. Of course, my experience is not from the track but probably at similar speeds in some cases.
I find the car pushes huge with stock tire pressures (35/45), but once I bumped the front up to 40 it balanced out quite nicely.
How was the comfort for the ride home? How rough are your city streets? I'm considering X74 but am paranoid of a harsh ride around town.
Ironman 140.6
Play will your pressures, check the bars to make sure you have the correct units installed. Additionally, you could consider some additional front camber.
Doesn't sound right to me. the X73/X74 use the M030 sway bars. My car used to have M030 and it certainly did not understeer more than a stock 996. IMHO the X73/X74 really wants the adjustable GT3 sway bars to be ideal, check it out.
Ironman 140.6
I agree. When I put the x74 on my car it decreased understeer over stock.
Lifting the front inside tire? What setting is the front sway at? It may be set too stiff. You may want to fix that first and work from there.
Not sure what sways the x74 comes with - I would think GT3 sways. I have the ROW M030 and upgraded to GT3 sways - and they are very different from one another.
I have it on my '99 C2 and it is not harsh at all. Now the car is a lot lower so pot holes, steep drive ways, speed bumps, etc. you have to be more careful with (avoid them if possible), but the ride is 'solid' or 'firm' whatever word you want to use, just not harsh. It's a great setup if you want to street and track the car and not have to deal with adjusting anything.
Not sure what sways the x74 comes with- I would think GT3 sways. I have the ROW M030 and upgraded to GT3 sways - and they are very different from one another.
Thanks for all the input. Sounds like if all is well generally, X74 should not be pushing more than stock. I'll check rear bar p/n's this weekend.
1) Tires - Dunlop SSR's - 26 cold, 35 hot f/r. Not great tires, but I am used to them and they like it a little low.
2) Sways are non-adjustable.
3) Toe is 0 front. Don't recall the backs, but slight toe in. A knowledgable friend is recommending negative toe if all else checks out.
I was thinking I need to go to 245/285 F/R tire sizes anyways. Really need to check that rear bar first. Lifting the inside front I think is a bit extreme for what is still a soft suspension (X74). Gotta be the wrong rear bar. BTW, I didn't get the 2 little plates that bolt in the rear engine bay somewhere. I'd be surprised if that made any diff, but....
Thanks for the input folks. Gotta love this board...
996-502-813-90-GRV - L/R Reinforcement Brace
996-502-814-90-GRV - R/R/ Reinforcement Brace
996-343-701-21 - Front Swaybar
996-343-792-12 - Front Swaybar Bushings
996-343-701-26 - Rear Swaybar
996-333-792-25 - Rear Swaybar Bushings
245's on 18's right, 245's on 19's will rub on turning.
There is also a colour code to know what bars you have, I have seen it on another thread but cannot recall which one.
