H&R Springs - Will they damage my 996 C4S???
I did the right thing by searching the forums for ways to lower my car but there doesn't seem to be any consensus on what long term impact lowering springs would have on the health of the car.
Personally I don't care about stiffening the car too much, just want the lower center of gravity AND have a sleeker look (guilty as charged). But I don't want negative performance attributes or long term damage. These springs would be $500 solution, or should I really go and spend the $3k for x73/74/pss9?
on a C2/C4, sure they will be noticeable premature wear on the shocks.
On the C4S, I am sure there will still be premature wear though I doubt it will be much more then what the standard shocks and springs get.
I've put 48k km on my shocks and they feel the same as before the springs.
I've H&R springs with stock shocks on my '00 C2 Cab. It eliminates the wobbly stock suspension feel and lowers the car quite a bit. I like the set-up a lot and although the main concern in terms of handling is that the shocks are to slow in adjusting, I don't really feel that this is an issue.
You won't demage the car. The only potential "demage" is that your stock shocks may wear early due to the higher compression. My decision was based on the fact that my stock shocks had less than 30k miles on them, so they'll probably make another 20k miles (3 years in my case) even under the higher compression.
However, a big part of the cost changing your suspension is the involved labor/time so it might be worth looking into a spring/shock combo. There a cheaper solutions out there than $3k - not even PSS9 costs you $3k in parts (more like $2k).
What I'll do when my stock shocks are done one day is combining the H&R springs with matching Bilstein shocks.
Well I will speak from experience:
I had the H&R Lowering Springs (Sport) on my 1999 C2 for 3 weeks before I removed them and installed the x74 system. And this is why:
With the springs, the shocks/struts are always in a compressed state. Sure it looked good with the whole car being lowered and having the center of gravity lower for better cornering, which I got, but a situation that I experienced that has been mentioned in other threads about using lowering springs on stock shocks/struts, and that is bouncing/floating at high speeds (aka POGO).
When going any speed over 100 mph the front suspension (primarily noticeable because it is the lightest) would actually depress a little when you hit a bump in the road, but then the shocks/struts would rebound (extend) towards there normal length afterwards and then back to the spring height, this was more than I liked and made the car unstable for a few seconds until the suspension came to rest again. To me this was unsafe and unacceptable especially when it happened during cornering. So I removed them and put in the complete x74 suspension which gave me a spring and shock/strut combination that works.
Now I have heard that you can mate the springs with after-market shocks. I do know people that have just springs on there stock suspension parts knowing that it will wear the shocks/struts faster (because of the extra compression the springs are doing to them). And I understand that these people have no problems with that extra wear and do not have any ride issues. But again with my experience it was too dangerous to use at speed or if I was going to DE/AX the car.
So I suggest you invest in a complete system of springs and shocks/struts and do it all at once.
So this was the fastest I have ever installed a mod on a car and removed it.
It might be a bit different on other models but you will never convince me it is OK to do this to a Porsche again if you plan on driving it fast or on a track which I do.
Jeffery Chen (01-23-2021)
... When going any speed over 100 mph the front suspension (primarily noticeable because it is the lightest) would actually depress a little when you hit a bump in the road, but then the shocks/struts would rebound (extend) towards there normal length afterwards and then back to the spring height, this was more than I liked and made the car unstable for a few seconds until the suspension came to rest again. To me this was unsafe and unacceptable especially when it happened during cornering. So I removed them and put in the complete x74 suspension which gave me a spring and shock/strut combination that works.
No my shocks were good with only 30K on them. I had an Indy shop install the springs and I specifically asked to make sure that my shocks/struts were still good or do not proceed. Maybe you just happen to be one of the fortunate ones that has not experienced the issue, or maybe you do and don't know it or have gotten use to it, who knows. But I know several others like myself that have experienced this issue and got rid of the springs shortly afterwards hence my input on this subject. Again it was unsafe for me to drive the car and once I went to the x74 I had no problems at all.
Thorin,
If I were you, I will do it right and change to coilover. Are you DIY the spring? If not, it is going to cost you and it will cost the same on labor for changing to coilover. C4S is different from C2, a bit more work in front, drive shaft need to remove from wheel well ......
PSS9 for c4s is around US$1900 from shox.com, very good price. After you paid duty, it is still alot cheap than in canada.
MTB
MTB
So if I were to go with the PSS9's, do I select the one for the C4 or the one for the Turbo? I searched several sites (including shox.com) and couldn't find one that specifically referenced the C4S. Do you guys just buy the one for the C4 or the one for the Turbo?
I'm pretty sure you need the one for the Turbo. The C4S has already out of the box the Turbo suspension as it has almost the same weight. I know that H&R springs are already different for the Coupe and the Cab so weight seems to make a difference when choosing the spring rate and the NB C4 is lighter than the WB C4S. You obviously can not go wrong with the Turbo suspension.
I'm sure to install RoW M030 in my C2.
I asked a question about H&R springs, but I'm convinced to get what Porsche engineers designed and tested lots of miles. I proved M030 in a C2 before and after and I love it. I didn't know that H&R works with the standard shocks compressed.
Besides, It's very important a good alingment.
