Got a Check Engine Light. Had the code read at Autozone and it came up as a P0455 evaporation system large leak on the read out. Per guideance here checked my gas cap and it was loose.
Safe to assume that this # and explanation corresponds to the loose gas cap I found?
Had them re-set the light and it hasnt come back on.
P0455 Fuel Tank Ventilation System (Major Leak) - Below Lower Limit
Potential causes: - Tank cap missing (or loose).
- Ventilation lines detached from EVAP canister.
- Ventilation line detached from tank.
- Ventilation lines detached from operating vent valve.
- Ventilation line detached from fuel tank vent valve.
- Break in ventilation lines.
