anyone actually use 93 octane gas?
Originally Posted by RSKY BIZ
Check out Street Blaze, street legal fuel from *VP Racing Fuels in San Antonio, official fuel supplier of the ALMS, btw:
"Oxygenated with ethanol, this CARB-legal fuel is specifically engineered for high-performance street cars including sport compacts, muscle cars, street rods and more. It's environmentally friendly and street legal throughout the U.S. In applications with anything from 4- to 12-cyclinders or engines equipped with a turbocharger, supercharger or nitrous oxide system (NOS), StreetBlaze 100 will generate optimum power and performance. In turbocharged or supercharged applications, it allows an increase in boost without fear of detonation. NOS users can also leverage their higher octane ratings to step up to a more powerful nitrous oxide system. Dyno tests with a turbocharged application proved StreetBlaze100 generates up to 14% more horsepower compared to premium grade 91 octane unleaded gasoline. Designed for use in cast-iron head engines with CRs up to 13:1 and aluminum head engines up to 14:1. Works well on the latest generation of electronically-controlled turbo engines. Contains no metal compounds and won't harm catalytic converters or oxygen sensors."
• Color: Orange
• Oxygenated: Yes
• Motor Octane: 96
• R+M/2: 100
• Specific Gravity: .746 at 60° F
VP RACING FUELS LINK
They even ship it to you...
Oh, yes, I use 93 Octane... so as not to hijack the thread!
Kim
*no affiliation... fuel info provided as a renne bene - fee free!
• Color: Orange
• Oxygenated: Yes
• Motor Octane: 96
• R+M/2: 100
Kim
Interesting, I will have to investigate.
Chandler!
Originally Posted by Tippy
Is pigs *** pork?
Does a bear **** in the woods?
The bear looks over to the rabbit and says "does **** stick to your fur?"
The rabbit says smuggly "nope, not my fur."
So the bear wiped his *** with the rabbit.
Im in San Jose.. so to fight the 91 Octane deal, I tried using an Octane Booster once.. huge difference at the low end. Usually my car is really weak around 14 mph or less in second gear, with the boost I had much more power around there.
Also, at high RPMs the engine sounded much much nicer, like it was happy to be there.. where as with 91 it sounds freaking pissed off.
I have also heard about Foxworthy and Almaden.. I have to make a trip there. I've heard of racing gas at a Unocal 76 around Redwood City as well.
Anyone know where you can buy 100 octane in SoCal (other than the race tracks??)
Shark Slayer
Location: 'BETWEEN NORTH STAR BOROUGH...& THE CONCH REPUBLIC'
1 Post
YOUR VP RACING FUELS QUESTIONS GET ANSWERED!
I have never heard of the stuff and I live in San Antonio. Family uses VP for the drag cars. We used to have a Shell station that sold 110 octane (well, there is no such thing as octane over 100, it is called heptane) striaght out of the pump.
Their tech director is a good resource for any questions, as well:
VP TECHNICAL DIRECTOR
"If you have a technical question regarding VP's fuels, traction adhesives or other products, you may click on the link above to send an email with your question directly to VP's Technical Director. Please give a brief description of your application along with your question(s). You may also call VP's Technical Department at 812-878-2025, between 8 a.m. - 10 p.m EST, seven days a week. Note that nontechnical questions related to pricing, dealer locations, etc. should be directed to the appropriate VP Regional Office."
Click on the 'contact us' on their home page:
VP RACING FUELS HOME PAGE LINK
Let me know the results of your investigative work!
Kim
Originally Posted by porsche-t
Unocal 76 station at the end of the Pasadena Freeway (110) in Pasadena. I used to go to Whiteman Airport near Pacoima to get 100LL for my turbo bike.
Not to change the direction of the thread, but since we are on the topic of fuels (and aviation fuels), if any of you use a kerosene heater in the winter there is a better alternative. If your local airport can accommodate jet aircraft then you can obtain Jet-A fuel. Much cleaner than kerosene and burns cleaner too. It is a derivative of kerosene and close to diesel#1 so it works great in diesel cars as well. It also will not gel until at least -40 or -56 depending on brand. (I burn a few hundred thousand gallons of Jet-A per year...the way it was intended to be )
You may even get a hell of a deal. Fixed Base Operators (they pump the fuel at the airport) drain off a considerable amount of fuel every day from the trucks to check for water. This fuel is considered contaminated even though there will likely be no water present. You may be able to take this off their hands for little or nothing.
This is also the case with 100LL aviation fuel but it usually ends up in the fuel tanks of the airport equipment.
Sorry, back to the regularly scheduled program!
Originally Posted by aviatorX
There is 130 Octane fuel available in aviation.
I remember that fact from my aviation books (I am a part-time jet mech with an A&P). Octane stops at 100, heptane goes over 100.
Here is what my search of Heptane turned up:
"The straight-chain isomer n-heptane is the zero point of the octane rating scale. It is undesirable in petrol, as it burns explosively, causing engine knocking, as opposed to branched-chain octane isomers, which burn more slowly and give better performance".
