996 Forum 1999-2005
Second gear has disappeared?
Old 08-16-2007 | 04:51 PM
jdk1's Avatar
jdk1
Default Second gear has disappeared?
Last year I put a rebuilt gear box (Powerhaus II) into my '99 C4 due to a problem with third gear.
Today on the way to lunch I shifted into second gear and around 3,000 RPM the engine 'broke loose' from gear. It sounded and felt like a slipping clutch. No grinding, no noises, no warning. The other five gears work just fine. I can shift into second smoothly, but the there is no power getting to the drivetrain.
I don't track the car and I don't race. Is it possible that I've won the statistical lottery and lost two transmissions in thirteen months? Any ideas?
Jeff
Old 08-16-2007 | 05:21 PM
cdodkin's Avatar
cdodkin
I've seen this in some early cars - syncro issue I believe - always seems to be 2nd gear...
Old 08-16-2007 | 05:39 PM
jdk1's Avatar
jdk1
I thought of this as well and did a a few searchs. It seems that the syncros either cause grinding or popping out of gear. For better or worse I get neither.
Old 08-16-2007 | 06:54 PM
hdtwncam88's Avatar
hdtwncam88
99 with 66k here and 2nd gear is very tempermental...try to shift into to quickly and she grinds...needs a 2 step shift...1st to neutral then neutral to 2nd....no 1-2 shifts
Old 08-16-2007 | 07:05 PM
Yoops Racing's Avatar
Yoops Racing
Finally another 99 owner with my same symptoms...2 gear is a biatch...same thing on my car with 25k miles on it.
Is there a fix or do we just wait for it to detonate?
I am considering a tranny oil change just to see what particles come out....
I also notice tranny sticks when car is turned off, left into 1st gear over night or longer...now I leave it in neutral....
Tranny seems to be the weak link in my 99......
Old 08-16-2007 | 07:12 PM
jdk1's Avatar
jdk1
Is your second gear not working or just grinding? I always stop in neutral between shifts - no luck getting power to the wheels in second.
Old 08-16-2007 | 07:48 PM
99firehawk's Avatar
99firehawk
assembly error, hub came apart or something simialr,
pull the drain plug and see what comes out
Old 08-16-2007 | 07:59 PM
jdk1's Avatar
jdk1
Brad,
Thanks for the reply. If it dosen't sound like somthing simple to you, who works on the cars every day, I am going to cut my losses and send the transmission back to PowerHaus. It is the estimated thirteen hours of time I'm being quoted to drop and re-install the transmission that I was trying to avoid. At least it will give me a chance to get some new plugs in the car.
For the record, as of now PowerHaus is standing behind their work 100%.
Old 08-17-2007 | 06:21 PM
Yoops Racing
no this is the symptom
"2nd gear is very tempermental...try to shift into to quickly and she grinds...needs a 2 step shift...1st to neutral then neutral to 2nd....no 1-2 shifts"
.........and its has popped out of 2 twice by itself.....very alarming.....just does not seem right. It hates quick 1 -2 shifts.....prefers the lazyman 1 -------- 2 shift.
Every other gear is great....1st gear is really tall.....revs out very quick
Old 08-17-2007 | 09:57 PM
99firehawk's Avatar
99firehawk
13 hours for a 996 trans? :O if its not a turbo i would shop around
Quick Reply: Second gear has disappeared?
