996 Forum 1999-2005
Quick Cure for a lumpy or erratic idle!
Old 08-15-2007, 08:44 AM
LVDell
LVDell's Avatar
Originally Posted by Seeeu911
hmm... I remember reading somewhere that there is a coating on the inside of the TB or intake ? that carb cleaner will remove and cause other types of problems.....
care to elaborate? I would be curious as to what you are referring to. My thought would be, if there is, how would you be able to clean the TB?
Old 08-15-2007, 10:30 AM
Seeeu911
Seeeu911's Avatar
No.
Just a flash of memory that I remember reading somewhere.. that there is an internal coating TB or Intake ? not sure.... that can be damaged by harsh cleaners. Intake finish is critical to combustion chamber flow.
Personally I would not just spray into the TB without removing it for cleaning first. YMMV
nick49
nick49's Avatar
Great tip! thanks.
Just curious, as a Cab driver myself, I have taken a few short trips of less than a thousand miles in my car with the top down and loved the experience.
It looks like you had the top on, did the unusually hot weather out west have anything to do with that?
Old 08-15-2007, 10:36 AM
LVDell
LVDell's Avatar
No.
Agree. That's why I think the way OE suggested is best. Wet a cloth FIRST and clean instead of spraying the entire TB down with the cleaner then clean.
Old 08-15-2007, 10:58 AM
hwk72
hwk72's Avatar
We cleaned the TB when we put in the RSS Plenum on my car; it was indeed dirty and my idle is now so much smoother Tja, part of my Plenum placebo is now gone - thanks!
Old 08-15-2007, 11:01 AM
Orient Express
Orient Express's Avatar
Originally Posted by nick49
Great tip! thanks.
Part of the issue was the heat and humidity in the midwest, but the main reason was that I put the top on was that the car was much more quieter, and the aerodynamics were better, hence better gas mileage.
Rachel (Area 51) NV at the Lil Alien Inn
Old 08-15-2007, 11:09 AM
ArneeA
ArneeA's Avatar
Originally Posted by Orient Express
Brilliant minds think alike!
LOL How about clogged-throttle-body-996-owners think alike!
Old 08-15-2007, 01:00 PM
AndyK
AndyK's Avatar
I'll definitely do this when I change my air filter!
Old 08-15-2007, 05:45 PM
pat056
pat056's Avatar
Thanks guys. Another happy Rennlister!!
My weekend project er... uh, AFTER I change the wife's cabin filter in G35
Old 04-29-2015, 07:55 PM
Dr.J
Dr.J's Avatar
Greetings. I'm just about to clean the throttle body of my 06 Carrera S, 997 3.8! A technician told me the butterfly cannot be opened by hand (will damage it), only electronically with the key and accelerator pedal. In the primary explanation, above, we're advised to do it by hand. Which method is correct? Or, is the 997 different from the 996 TB?
Thanks!
Quick Reply: Quick Cure for a lumpy or erratic idle!
