Hearing bells or beeps???
Originally Posted by gota911
Tippy - he originally stated "why every time I started out in first gear, there were two distinct but subtle beep-beep tones."
You might have something Tippy. I washed the car tonite...and took it for a dry off drive. for the first time, I heard the soft "ding-ding" and pulled over. I started out again and watched the speedo..and at 18 mph heard the ding=ding. Did this several times and verified 18mph.
Went home and got the wife to drive...buckled both seat belts to eliminate that. Removed the radio face to eliminate that....and at 18 mph...ding-ding. She said she also heard it as the speed dropped down between 18-20 mph, but with the mufflers I couldn't hear it.
So my brother wasnt' nuts...if he was smoking something or chewing shrooms, that didn't cause any hallucinations. I think that possibly Tippy might have something and I'll have to go read the owner's manual about activating/setting the speed alarm.....but you'd think that it wouldn't have the abiliy to be set below 50 or the usual speed limits....but I dunno. Tomorrow I'll try Tippy's suggestion.
In my car (2003), the speed warning when set will flash on the dash as well as ding but then the ding is only one ding and not two.
Could you have something loose that rattles at a specific harmonic which is coming out at that low speed? Maybe it's still there at other speeds but it can't be hear over the tires or motor?!
Washers make a dinging sound. Now I haven't seen any washers on these cars yet, not that I have looked for them either but it was a thought.
Can the wife or brother locate a specific region in which the sound is coming from?
I set mine at 166 MPH so I never hear it again.
AND THE BRASS RING....goes to Tippy....it was the speed control after all. I followed your directions and managed to cancel the dings. By coincidence the speed control was set to 19 mph. My average fuel consumption was also at 19 mpg...so when I'd go thru the onboard computer features, I'd see the 19 and figured that it was the mpg, so I overlooked it as the speed control.
Tippy....it did display a 19 with a greater than arrow...and I looked in the manual and that particular feature is listed under the caption of "Gong"....which I guess is what you can call the dings.
So thank you for the correct answer and solution to what was driving me nuts. Also, according to the manual, you can set that gong for speeds all the way down to speeds "higher than 6 mph"...and it's done by pushing the onboard computer stalk forward for 4 seconds. My last gas fill up, I recall going thru the features and resetting them to zero as I usually do. I must have inadvertantly set the speed gong at that time.
Thanx again. Case closed. Time to deal with some other dummy.
Newbies Hospitality Director
AND THE BRASS RING....goes to Tippy....it was the speed control after all......
Chuck, we like dealing with you, 'cuz you are our favorite dummy!
Chuck, of course, I am just kidding! Hell, I am a bigger dummy, 'cuz I didn't even remember we had a Gong. Maybe they changed the warning signal in the face-lift cars, 'cuz any time I go too fast, I hear "HEY, SLOW DOWN, DUMB ****!" The really strange part is that it sounds just like my wife's voice.
Tim: One of the guys said he set his speed reminder to 166 or something like that so it would never go off. I just have a habit of every time I fill up with gas.....that I go through a cancellation process using the stalk to zero out all the various categories like average mpg, mph etc. I never even knew there was a speed minder feature in there.
Oh...and I don't mind being labelled a dummy....if the foo ****s, wear it.
