Changed out battery, ABS and battery light stay on
Originally Posted by Loren
A little more info please...
model year, model and miles?
any 3rd party electronics?
any change if you wiggle the key in the ignition switch?
It's a 2000 C2, 42K miles. I have a Sirius unit installed over a year ago. That's about it.
The first time I drove it after changing the battery, there were no issues. The issue came afterwards.
Wiggling doesn't seem to fix...
Try a reset - disconnect the battery for 5 minutes (got your radio code). Then reconnect it and see if anything changes. You are connecting positive to + and negative to - right?
Try a reset - disconnect the battery for 5 minutes (got your radio code). Then reconnect it and see if anything changes. You are connecting positive to + and negative to - right? ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
