GT3 seat guys - what are these mount points?
Originally Posted by LVDell
Ah, I see what you are asking now. Yes, you do remove the seat belt receiver from the stock seat and re-attach to the euro seat in the same way. As for the tunnel mount I do NOT use them. Instead I run and outside mount on BOTH sides and they are anchored down on the floor under the rear seat bolts. Mounting the lap belts to the sides of the seat was just too close and didn't offer the ease of adjustability that you can get with more slack to play with.
**here are two pics....one of the tunnel side and one of the outside and BOTH lap belts anchors are mounted to the floor under the seat bolt. I have tried several different ways and like this the best.**
Hard to tell from the pics, but did you fabricate the anchors? Do you have a seperate picture of the anchors? Thx.
Originally Posted by SMR996
Kerry,
I went out and took these just now....... Does this help?
The bolt screws into the side of the seat with the bolt from the stock seats.
I plan on using the R-9004 for the inner and outer mounts on the GT3 seats.
Any reason why you used the R-9003 instead?
Originally Posted by canysmc
I see. You took these mounts and mounted under the rails. Did you use longer bolts at the rails?
