996 Forum 1999-2005
Technical Question - Blinking overheat light when temperature is normal
Old 04-03-2019, 09:49 PM
T.Dub
T.Dub's Avatar
I'm running into the same problem- slow blink all the time, coolant level is correct, no cracks in tank (just replaced), engine temp sensor is fine, and the engine bay fan works (tested with scantool). Going a bit crazy tracking down the problem- perhaps the new coolant sensor was defective? Just received a replacement and am going to swap it out.
Old 04-04-2019, 01:41 PM
dporto
dporto's Avatar
Received 1,165 Likes on 795 Posts
Originally Posted by aeichmiller
Checked the fuses and they are fine. I didn't see a relay on the fuse box diagram. Is there one somewhere other than the fusebox?
^^ Rear parcel shelf (under foam/carpet cover)...
Quick Reply: Technical Question - Blinking overheat light when temperature is normal
