Rear spacers before and after on C4S - Opinions.. (PIX!)
Attached are the before and after photos with the H&R
14mm rear spacers on my C4S. I have to say I like the look but
somehow to me it seems that they madde a bigger impact on
my Boxster. What do you think.?
Before C4S
After C4S
Overall C4S
Boxster
Overall Boxster
Before C4S
After C4S
Overall C4S
Boxster
Overall Boxster
Bigger impact cause the 986 is quite a bit lower.
Appears you have OE ride height on the C4.....and no rake.......I'd definately drop it.
Nice cars otherwise though !
Greg, excuse my ignorance, what is rake? ( I will guess..The height of the front vs. the back?) I could see the front 3/4" lower. how can this be acheived? Can I do front only. I like how the rear sits but I have noticed the front looks a little high.
I think if you lowered and used spacers, that's when you'd realize the biggest visual impact. The car doesn't really need spacers at stock height. It's only when that camber changes due to lowering where a spacer really helps to push the inset wheels out a bit. That wheel gap on your C4S looks insane, almost 4x4, bud!
Spacers should be avoided at all costs, IMO. It's a stop-gap piece that makes up for ill-fitting wheels.
And rake is not great unless you're into the dragster look.
Most think it's basicaly cosmetic.....but it can have some effect on handling, at least on the track. Porsche supplies front and rear height ranges for all models, US Turbo, ROW, X73, GT3, GT2, etc.
As example, GT3 is pretty darn low and the I think the front to rear differential is around 13mm.
Only way you can set all height just where you want it (along with rake & corner balance) is with adjustable suspension.
So..........this is one of several arguments against just using springs to lower your car. Personally, I think there are some cases where 'just springs' may be adequate........and if they are designed correctly for your specific model (C4 vs Cab, vs C4s, etc) then the manufaturer probably took the resulting rake into account and hopefully the car will sit where you want her.
If you don't like where she sits.....you're basically done.
With adjustable set-up you can go up & down to your hearts content.....you can stick to Porsche height & rake....... or modify, correct, etc.
Cheapest way, springs. But you dont want to just change the front ones and leave the ones in the back stock, since you will have different "roughness" in the fron and in the back.
Alot of comments about my ride height. Now I have a complex. This is stock, it's just how it comes, right?
Your's is the only opin that matters.
Some people are **** on ride height and have suspension parts waiting at the shop when they take delivery........that's their thing.
US DOT mandates PCNAs ride heights.........a car bound for the U.S. is different than Euro and others. DOT is hung-up on both low-speed crash test specs as well as headlight beam angle...........Porsche 'solves' these problems (of dealing with our federal government) by cranking the suspension up in the air.
Write your congressman.............what a joke that is.
Originally Posted by GreggT
John........don't listen to anyone.
here's my Ben Choi ride height just for comparison (PSS9)
Not posting it to boast or anything i couldn't care less.. just showing you how I like it. it looks even better in motion. wide and aggressive due to aero and lowering and wheels.
For what it's worth.........OE USA ride height is 158 (plus/minus 10mm) in both the rear and front.
Here's 2 pics just off the showroom floor before being dropped off at the shop (where all the suspension parts were ).
Actually, I did have it up on jackstands for three days while the wheels were off getting repaired. I do believe I just let it down before taking that pic. It never crossed my mind. That could explain some if it. I am going to check it again when I het home. I feel somewhat better now
