Installed aluminum dash strips
I'm right there with you! I've orders these countless times from Eric and backed out of the shopping cart. I want to do the install without tearing the old one up, but my concern is not having access through a glove box.
Believe me I understand your worries. I really wanted to unscrew the existing pieces and tried my best, but either I didn't have the right tools, dexterity, or I don't know what, but I couldn't get those last two screws to save my life. Eventually I just said F it, if I damage the dash I'll just go out and get the leather one I've always wanted. But the trim pieces will and did break before any damage is done to the dash. After I did that I wondered why I spent all those hours going after four little screws
As the OP of this thread a few hints to get the small strips off neatly: you must remove the plastic trim piece at the base of the steering column. A small ratcheting wrench with the right Torx bits is the only way to get in there. I also used a small telescoping inspection mirror to help me line up to the screw heads.
Phil, thanks for the original write up. It was really useful. I think the key is a quality ratcheting wrench. Mine had a little too much play between ratchets and that made it difficult since there's little room to move around inside the dash even with the plastic trim piece you mention removed.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Do you have more detailed pictures at the removal of the passenger side panel below the airbag? Mine is making rattles that makes me crazy. I have been delaying dismantling it to re-tighten everything under there because one I am not totally sure how to do it without damaging the leather panel, and 2 I am kinda lazy to work in the garage under 110 degree heat
Cheers,
I don't think anyone ever figured out how to do it on cars with no glove box though. I don't know what's under the airbag in pre 02's but it must be solid and inaccessable from underneath. That's why the other method that Phil chose not to follow seems to be the way most others have done it. I'm sure the fastest method is the rip it all apart way. I'm still scratching my head about how Phil was able to do it the hard way in just two hours.
Well done Phil
Real delicate work ... the end result is subtle, but makes a very nice difference IMO.
You're correct on the labour costs ... I took the easy way out, Pfaff charged me 3 hours, you're a braver man than me
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
