Tip to manual conversion questions
Originally Posted by 99firehawk
dont forget all the hydrolic lines and the slave cylinder and the operatng arm and the flywheel and pressure plate and clytch disc and release bearing and and and and and
Please help out I did a conversion too
Hi
I did the conversion too on my 2003 996 c4 tip to manual, the trans part is fine and straight forward, but after the swap my electronic throttle body is limiting its opening is it because of the ecu? How can I fix this?
