Check Engine Lite
Closeout at Amazon for $73
http://www.amazon.com/Actron-CP9135-...2110173&sr=8-2
Another alternative for $50
http://www.amazon.com/Actron-CP9125-...2110173&sr=8-1
Or another for $88
http://www.amazon.com/Actron-CP9175-...2110173&sr=8-4
...and enough left over for a few beers of your choice.
Or another for $88
if the exhaust rattles it is the cat converter
had my light come on and the exhaust was rattling....replaced the cat...something had come loose...all good now....agree with jumpers comment..
Thanks for all your feedback, I'll definitely consider getting a OBD reader!!!! I was able to fill up the car after I left the dealer and lite still has not come back on on which is good.
I am wondering if me not driving the car often has to be part of it. Sometimes I don't get to drive it for two weeks. And sometimes I only drive around the block which is less then 10 miles???
You are killing your car if you let it sit for two weeks and then only drive it around the block. Unless you are going to really drive it and warm it up all the way, it would be better to let it sit.
Get and OBD II reader and join renlist.org.they have a complete list of the codes for members Copy the codes for your specific model and keep them and the reader in the trunk. If you throw a code on the road you can look it up and decide to schedule a serviice $$ apt or just erase the code and see if it comes back on!!
Newbies Hospitality Director
Location: looking for a job ... Colorado by bye 996 C4 :(
Today while driving into work I had my engine light come too. Just turned pass 60K on my 99 C4, car runs fine. Checked the gas cap it was tight. if i buy a reader where is the plugin?
996 C4S- I think that you car is mad at you for letting it sit for a few weeks. The check engine light was its way of letting you know that you should drive it more.
RAC- the plug is on the drivers side near the fuse panel. It is between the fuse panel and the steering column. It is purple.
Down by your left leg. Should look something like a printer port. Do pick up a cheap code reader - a must have when trying to figure out what is going on.
I guess that I wasn't very clear when I said between the fuse panel and the steering column. Maybe a better explanation would be- just below where your left knee would hit if you were in an accident.
This is a great thread. I've been meaning to get a code reader adn this reminded me why.
I just bought the $49 Actron CP9125 - and I got $30 off by signing up for an Amazon Visa card. Such a deal.
ok ... I had codes P1128 and P1130 looks like it might be a MAF going on its way out. What is the cost on a MAF? anyone have a diagram?
