Bad engine noises at specific RPM ranges?
It is like clockwork. At exactly 2,200-2,300 & 3,200-3,300 & 4,100-4200 RPM there is a metal on metal sound
. Increasing and decreasing RPM has the same result. Does anyone have an idea of what could be causing this?
i feel i have the same problem.
i can feed the metal2metal vibration on the streeing wheel.
my car is 996 MY2001 3.4 tip, 50KMile. last oil change was last year spring.....
Originally Posted by wdonovan
If you're lucky, some junk rattling inside a cat.
Originally Posted by 99firehawk
why are you reving the car in neutral, what are you hoping to acomplish.
timing chain vibration engine knocking......where do you guys come up with this stuff
Are you drinking again Brad? No one said anything about reving the car in neutral.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
J.Seven
