Battery dead, front hood locked - help!
I've read this before - and for the life of me I can't seem to dig up the post. I read several posts telling me to supply power into the fuse box area (this doesn't exist in '99 996's - like mine!).
Anyway, 1) Can I trickle charge from the 12V cigarette lighter port ? I don't know if it's connected back to the battery (or lock/unlock mechanism) even when the car is off. Where can I get a cheap one from Autozone/Kragen/etc? I can't order online since I'd need it this evening ... 2) There was a post on removing the door strip housing the hood release lever and unlocking the hood. Anyone knows how to do it or where that post is? (I can't find it :banghead: ) |
Wait, I thought on the '99 the hood latch is a mechanical operation and not electrical? Pulling the lever by the driver's sidesill doesn't open the front hood? If you do need power, then yes, you can trickle charge the battery via the cigarette lighter. That's where the battery maintainer is plugged into.
My '00 has manual hood and trunk pulls. Were electric ones an option in '99?
My 2000 is mechanical, if it has electrical, I dont know where.
:rtfm: Im pretty sure it has instructions on how to open the trunk when the battery is dead
Not exactly. Its an electromechanical lock. Mechanically operated, but electrically LOCKED. I need electricity to unlock the lever itself THEN mechanically use the lever to unlock the hood.
I'm thinking this "Pilot Porta-jump " might do the trick of unlocking the locks. I'm not sure about jumpstarting the car with this. Wouldn't the high current demanded by the started motor melt the cigarette lighter wires? Or are they saying I should trickle charge for 30 mins THEN start the car?
Anyway, can anyone with a MY99 manual tell me how its done in that case? Thanks Sid |
From page 92 of my manual (for a MY2000)
Note When the battery is discharged, the lever for the front hood can't be unlocked. Using jumper cables, the battery of another car can be used to open the front hood. To connect the cables, refer to "Emergency Starting with Jumper Cables"... Yeah, I know, what am I doing with the manual in my office? Stefan |
I'm thinking this "Pilot Porta-jump " might do the trick of unlocking the locks. I'm not sure about jumpstarting the car with this. Wouldn't the high current demanded by the started motor melt the cigarette lighter wires? Or are they saying I should trickle charge for 30 mins THEN start the car? |
The engine lid should pop regardless of power. Isn't there a positive battery terminal in the engine compartment?
Stefan |
Stefan |
The manual only speaks to the front hood needing power. I assume that means the engine lid is accordingly manual, and you can get to it with a dead battery.
Stefan |
Originally Posted by Tippy
Use the cigarette lighter port to unlock the hood, then remove the center plastic piece by the cowl, connect jumper cables to the battery post and jump from there the engine.
As a side note, I've been driving my girlfriends BMW 3 series convertible for the last few days, before and after the long weekend. I'd been LONGING to get into my car and met with the dead battery :( ... can't wait to drive it to work again tomorrow :) ... need some Porsche therapy ;) !! |
push start your car!
I'm going to try this in the evening when I get back home. And I don't have my manual in my office :). Assuming it opens, where is the terminal post?
According to the manual, inside a little black box marked with a +, on the right side above the air cleaner. Stefan |
Up until MY01 the front and rear lids were cable operated (mechanical). There is however a solenoid for locking purposes that locks the handles so that they can not be raised. That is the "electronic" part that keeps you from opening the mechanical releases.
Just use the emergency release under the right front wheel well liner. |
