Cabriolet rear side window trim
I was washing my car today and cleaning the interior too and noticed that the felt covered rubber trim on the leading edge of the rear side windows is looking pretty worn and slightly faded. Has anyone replaced these? I think I remember seeing these in an aftermarket Porsche parts catalog and they were quite reasonable in price.
I'm curious if they are easy to install as a new set would really look nice on my car. This is the only area that really shows more than average wear probably because I raise and lower the top a lot.
I recently changed mine, that is if I am thinking of the right part. Its an easy change, you just need to pull of the old rubber gasket and replace.
Here is the item numbers from Pelican parts
Item Name Item Price Quantity Item Total
OEM-99654361603 $10.55 1 $10.55
B-PILLAR GASKET
- This is a special-order OEM part and is non-returnable except for
warranty replacement.
OEM-99654361503 $10.55 1 $10.55
B-PILLAR GASKET
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
B-PILLAR GASKET
B-PILLAR GASKET
Anyone have more installation information for the Cab Window rubber gasket? The gasket seems to be in place very tight. I am not sure if I can get it back into place without removing the window.
B-PILLAR GASKET
2000 Porsche 996 C2 Cab
Eibach springs.
Short shifter B&M.
Fabspeed Exhaust. Headers
Agency Power Rear Adj. Control Arms,
OBC Switch, MP3 Wired,
280 30 x 18 Pilot Rib,
997 Air Box, Red Silicon Intake
Airbag Deactivation
B-PILLAR GASKET
Eibach springs.
Short shifter B&M.
Airbag Deactivation
