Will These 997 Turbo Wheels Fit A C2?
Gents,
Wil these fit a 1999 C2 narrow body? I know that Techart use a 11x19 ET52 on the rear, so will the same size wheel but ET51 push it put too far?
http://cgi.ebay.co.uk/Brand-new-Genu...QQcmdZViewItem
Many thanks.
Many thanks.
Even the TechArt wheels are going to stick out too far. A 19x11 et 52 will stick out 1" so 51mm will be slightly more. If you want a 19" OEM wheel, get the 19" Carrera wheels 19x8 57 and 19x11 et67. if you use a 3mm spacer in front and a 5mm in back, the centerline of the wheel will be exactly the same as stock. The fronts will stick in and out 1/4" and the rears 1/2" in and 1/2" out.
A Perfect fit.
A Perfect fit.
Newbies Hospitality Director
I doubt very seriously that they will fit on your '99 C2. As 2Brak said above, the rear wheels will extend a full 1" more than your current wheels. Don't buy them.
