How to do a before and after of Plenum
Ok I ordered the plenum today. There are over 20 orders for the group buy.
Any suggestions on how to do a before and after test without a Dyno? Or should I just trust the seat of my Pants?
Make a few runs at a drag strip before and after. If that's not practical you can set up a course on a road that sees very little traffic. Use an object for a "start" and another for a "finish". The distance between these points should be long enough that you can measure time with a stop watch or speed at the second marker with a GPS. You should make several runs and record the results. I would recommend trying different things such as approaching the first marker in 4th gear at 30 MPH and when even with it accelerating as rapidly as possible and if necessary shifting at 7k into the next gear and having a passenger measuring speed and time. Try different speeds and possibly different distances. If doing several runs the same, the results should be very close. Keep track and compare results. Make sure you record and wind and temperatures, humidity etc. as these can make a difference.
Have fun!
Have fun!
Steve, I'm part of the group buy also. I have a G-tech performance meter. I have previously measured my 0-60 and 1/4 mile times. I plan on doing it again after the plenum to see the difference. You might see if you can borrow one from a fellow Rennlister in your area.
Thanks for the ideas. I just remembered I have a first generation G-tech in a box somewhere.
Maybe I can figure out how to employ it to do a test. I don't want to do 0-60 or quarter mile type test because the start off the line introduces to many variances. Maybe I can use a rolling test from 60 to 80 or something I can do on the hyway that would be semi legal.
Have fun!
Have fun!
the difference is going to be in the tenths of a second, if not the thousandsths and to have a 'normal' human being so heavily involved in such a test is a sure fire guarantee that the inputs are not consistent. And as you are suggesting two humans be involved.......
Just do a run w a buddy side by side in same gears wo the Plenum. See the results. Then do a run same scenerio w the Plenum and see the results. If its pulling alot more then I would say its a good investment
The only porblem I have with the dyno is $$$. The G-tech test is free (unless you get caught doing the 1/4 mile run) and with a tiptronic the times are fairly consistent.
After installing them on, drive the car hard, it takes a few miles before the ecu recognizes the mod. Drive it like you stole it, then you will notice that your mid range power has increased and its a lot more smoother on the throttle and better response.
You will get a lot of negative feed back on this forum and just like any new product, when they get a chance to try one out they will look back and say damn, wish I new better. There are a lot of heels, but there is nothing we can do about them. They just have to try if for themselves to learn.
Best mods for more power as old school mods, intake dosent do anyting it the throttle body and intake sucks, basically its like a bottle neck, you want as much air in the engine, but the engine can only take so much in.
Originally Posted by Orient Express
This:
<<picture>>
and this:
<<picture>>
Have the same parents?
<<picture>>
and this:
<<picture>>
Hey - don't forget to put on that K&N air filter for even more performance improvements!
Michael
1 Post
HA! Actually, plenum replacements aren't new, not even for Porsche. The problem for me is that the same quality part I see for Mustangs are $169 vs our $765. This one for the 996 is the only applications I've seen that has no recommendation of changing the thottle body as well.
This:
and this:
and this:
