power window woes
Hi, 2001 996 TT has a problem with the driver window not staying in the slightly retracted position when the door is open. This causes the door to stay ajar when its closed. Its as if the computer senses the door latch being opened, retracts the window, but then runs it back up as soon as the latch is released. I've tried re training the window, all the tricks in the owners manual, advice via the phone from the dealer, but no luck. Is there a sensor that tells the computer that the door is open? Anybody seen any thing like this? Peter
Just repaired this. There's a switch inside the door handle assembly that is faulty. My Indy replaced it for about $150. I can take a pic tonight and show you the part.
The test is, with the door open, pull and hold the door handle open. If the window retracts normally, and then goes back to the closed position when you release the handle, its the switch in the door handle.
This is the microswitch that I thought of when diagnosing the issue with my Indy - but he actaully changed the door lock module which is part part number 8N1 837 015C - not sure if he replaced the micro sitch as well.
DO you have a diagram of this part - I have the one that was removed but my camera is dead.
Newbies Hospitality Director
