No instrument lights
I drove my car the other night and had no instrument lights. All of the fuses are okay. Has anyone else had this problem. I am still under warranty, but wanted some input before heading to the dealer. Thanks for any help.
It happens. I was told the light switch assembly needs to be replaced. I can get the instrument lights to go on with some fiddling (turning on and off, twisting back and forth), and also eventually they come on. If you can't do that, it's probably time to replace the switch. Especially if you're under warranty.
Piccia
Piccia
Piccia
Mine was broken off by PO.
Are you saying the switch is replacable. I was under the impression that the whole instrument panel needs to be replaced. Do you have a part # for just the switch ??
Originally Posted by lfe
Piccia
Cluster **** info is here
-td
