Oil Level
The other day I was checking my oil and noticed that it was a little low. It was within the hash marks, but low.
After reading some of the post here re RMS issues I decided for preventative purposes to add 1 bottle of Stop Leak (which is less then a qt) in place of the oil. This morning my Oil level on the dash showed too high. should I try to syphon some out through the dip stick or am I OK
Ignore the electronic gauge and take a look at the actual dip-stick
Car on a level surface - leave it at least 30 mins after driving before you check the level.
Let us know how that looks.
The electronic gauge is questionable for accuracy... And I'm being nice here...
Plus the apparent oil level will go up and down with
1) Driving - if you measure too soon after a drive you get a false reading
2) Driving style - short drives allow condensation to build-up and not burn-off from the oil, leading to higher apparent oil volume
3) Oil temp - oil expands when hot giving a higher reading than when cold
4) Level car - if your garage is not absolutely level, you'll get a false reading - my garage slopes slightly towards the door/rear or the car, so I get a false reading when I check oil level
Originally Posted by AndyK
Damn! I thought that little electronic oil gauge was so cool! Thanks for crushing my dreams!
They don't even get a dip stick so have to reply on the electronics
Not sure if anyone is interested, but I needed a cheap cup holder solution. I found a door mount model with both a suction cup and in door tab for added security from auto barn that was about $5.
http://www.autobarn.net/acsmz.html
I personally couldnt use center stack one becasue I already have the radio, amp and climate control. Additionally, I dont have any hole in my vents for the vent mounted one.
This was a cheap solution and if fits fairly well between the door grab and the dash. A little awkward with the ignition but that no big deal
Has anyone else noticed a problem similar to cdodkin?
cdodkin wrote: The electronic gauge is questionable for accuracy...
Agreed- in both a 3.4l and 3.6l the gauge was quite accurate. I agree with cdodkin, that the level is off (usually low) right after a drive... it seems to be higher after letting it sit for a while (probably 1-2 bars)
