996 Forum 1999-2005
Window doesn't Stop
Old Apr 18, 2007 | 11:48 PM
Loup's Avatar
Loup
Question Window doesn't Stop
I did the searches and found many topics about the P/Ws not going down all the way. My issue is that when you open the window it won't stop. I hesitates around the 4-5mm position but then continues to travel all the way down. Once down and the door is open the switch won't raise is again. If I shut the door then I can raise it back up. Is there a controller for the P/W's? Ideas?
It's a 03 996 Cab.
Old Apr 19, 2007 | 03:06 AM
joes c4 cab's Avatar
joes c4 cab
Can you help the window up or down? Sounds like you need a new regulator. I did this one in my cab by having the door cracked when I put the top up. The top was thinking that the window was down and when it latched all the way, I heard the window "pop" which was basically the teeth being removed from the regulator which makes it go up and down.
Not a difficult swap and not too expensive. Cured my problem.
Old Apr 19, 2007 | 04:21 AM
Porsche_Smile's Avatar
Porsche_Smile
new motor..... that happened to mine and about 2 weeks later, the motor just craped out.....
Old Apr 19, 2007 | 09:18 AM
99firehawk's Avatar
99firehawk
try un hooking the battery and jumping the cables together for a second, (battery unhooked or out of car) then reinsatll the battery and re program the window by holding it in full up and full down for about 5 seconds in each direction twice
