996 Forum 1999-2005
Went for a drive last night-car tramlines a lot - normal?
Old 04-17-2007, 11:28 AM
AndyK
AndyK's Avatar
Default Went for a drive last night-car tramlines a lot - normal?
I noticed the car following grooves in the road on the way back from picking it up on Long Island. When I got home, I found the tire pressures were all over the place, so I filled them up, and headed out last night. Car still tends to fight me, like it wants to go it's own way when it hits bumps or channels in the road.
The rear tires are new, the fronts are a little worn. 18"ers
Is this just sensitive steering that I am not used to, or do I have a problem?
Old 04-17-2007, 11:31 AM
Benjamin Choi
Benjamin Choi's Avatar
of course it's going to wanna fit into the grooves
Old 04-17-2007, 11:32 AM
redridge
redridge's Avatar
thats called tramlining its normal on the most part but might want to consider corner balance and alignment...good excuse for a suspension upgrade
Old 04-17-2007, 11:36 AM
nick49
nick49's Avatar
They pretty much all do this. Wide tires with low aspect ratios and stiff sidewalls make it worse as does low tire pressure. A lot has to do with the roads too. Get used to it :-)
Old 04-17-2007, 11:38 AM
AndyK
AndyK's Avatar
Yeah, that's the term I was trying to remember! Would a good alignment geared towards street driving (as opposed to the track) allow the car to settle in easier on the road?
Old 04-17-2007, 11:48 AM
cdodkin
cdodkin's Avatar
Varies by tire size (width) and manufacturer (tread pattern) - so you may want to review what's on the front wheels and change out for something different.
Old 04-17-2007, 11:50 AM
AndyK
AndyK's Avatar
I have the old (original?) Conti Sport 2's on the front, and new Conti Sport Contacts in the rear, replaced before the dealer sold me the car. To get all the tires to be new and matching, I would have to buy 2 Conti Sport contacts for the front. But those tires don't get good ratings at Tirerack, so putting good money to bad might not make sense?
Old 04-17-2007, 12:25 PM
rcg412
rcg412's Avatar
I find the 996 has very sensitive steering, always course correcting. Plus given the roads in the tristate area, get used to it!
Old 04-17-2007, 12:51 PM
RAC
RAC's Avatar
Location: looking for a job ... Colorado by bye 996 C4 :(
It’s the tires. I had Conti's on my A4 which tramlined horrible. After switching out the tires I didn't have the problem anymore. I also have very little tramlining on my C4. My $.02 is that it is more due to the tire and tread pattern. Switch out the Conti's and I bet your problem goes away.
Old 04-17-2007, 12:54 PM
evansaero
evansaero's Avatar
You need an alignment
You don't need new tires
Old 04-17-2007, 01:08 PM
UCrazyKid
UCrazyKid's Avatar
Alignment. See if you can get the dealer that sold the car to foot the bill.
Old 04-17-2007, 01:26 PM
Blackness
Blackness's Avatar
I had Conti's on my car when I first got it. The fronts were the original SC's and the rears were SC2's. I now have Michelin PS Ribs. The car has never tramlined on even pavement. It still doesn't tramline too bad on a grooved road. Certainly not near as bad as my best friends C5 Vette.
My vote is to have the alignment checked.
Old 04-17-2007, 01:32 PM
AndyK
AndyK's Avatar
I'll get an alignment. I wont bother calling the selling dealer, who will say the alignment was fine, and that I must have hit a pot hole, etc, etc. Cost of doing business with a small dealer 2 hours away!
What does a 4 wheel alignment usually run, so I can see if my mechanic is honest?
Old 04-17-2007, 01:40 PM
evansaero
evansaero's Avatar
Cost at my dealer down here was $105
Only a dealer or race shop will be able to do it. A reg alignment shop will not be able to do it. You should be in and out within 2 hours
Old 04-17-2007, 01:41 PM
Blackness
Blackness's Avatar
A local indy who does good work (a lot of the PCA'ers use him) charges $150. The dealer $250.
Quick Reply: Went for a drive last night-car tramlines a lot - normal?
