Went for a drive last night-car tramlines a lot - normal?
#62
Originally Posted by VGM911
Andy,
For what it's worth, the Potenza RE50s are not N-specification tires for the 996. They do, however, get good ratings on the Tire Rack website.
If I was doing DE's I would respect the "N". Not in my case though.
#63
I don't have N-spec tires on my car, either. I have Bridgestone S-03 Pole Position tires, but they've been discontinued.
I'm in the market for tires, and I'm thinking about getting the Bridgestone Potenza S-02 A tires. They happen to be N-spec, but the RE50s are a worthy competitor. Decisions, decisions!
#64
Bad tires that are balding badly on the inside of the tire could certainly have created a bit of the problem. New tires always makes the handling of my cars feel better, and given Porsche's sensitivity, it's to be expected that an out of whack alignment (esp. toe out as it sounded in your case) and rubbed tires can have an adverse impact on steering. I'll be anxious to hear what you think when you got the new rubber installed.
#65
Hopefully that will solve my handling issues. I should be getting the tires installed on Tuesday or Wednesday. I'll let you all know how it goes.
#66
Originally Posted by AndyK
I got the alignment. The toe was off, especially in the rear (.76 difference from spec). STS aligned the car. Took it out on the highway, and it STILL doesn't feel in control. Still have to jiggle the wheel back and fourth to keep the car from veering.
To add insult to injury, the alignment machine mauled my near-mint rims. I'm convinced as soon as you have work done to your car, it wont stay in mint condition.
Plan B is to bring it in to my indy mechanic, to see if he can spot a broken or loose part in the suspension.
And, my radio is worse, with the interfearance coming on right away. No cell phone near the car, engine off. Must be a ground issue, right? How do you get this head unit out of the dash? Another thread, I guess!?
#67
Here's an update. I went back to STS, to get the front wheels balanced (thinking maybe they were out of balance, causing my problems). When they took the wheel off, the inside half of both tires is almost bald !Very worn, I need new tires.
Would that be causing my problems?
And they damaged your rims!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
I'd be getting some compensation, then going somewhere where they take more care and know what the hell they're doing.
#68
Beauty is, my GE warranty covers ALL electronics, including the stereo. So, if worse comes to worse, and there is a broken tie rod end, I can bring it to Porsche, have them fix that, the RMS, and the radio, for a $200 deductible!
#69
Originally Posted by cdodkin
Andy - have to ask - how the hell could STS have done the alignment and not noticed the inside wear on the tires?
#70
The alignment has nothing to do with worn tires, and it was off, so I had to have it done anyway for the new tires. When I told the owner about the rim scrapes, he said there is no other way to clamp the alignment cameras on the rims. What can I do at that point?
#71
Addic
then he should have warned you that it may cause possible damage.. you dont just do something a particular way regardless if it will damage something. and obviously he knows it was his fault.
#72
Beauty is, my GE warranty covers ALL electronics, including the stereo. So, if worse comes to worse, and there is a broken tie rod end, I can bring it to Porsche, have them fix that, the RMS, and the radio, for a $200 deductible.
#73
Originally Posted by fw2001c4
sorry to hear about all that youre going through... just a word of caution. deductibles typically are for per occurence. so the three things you mentioned would be three occurences or 200x3. doesnt matter that you take it in at the same time. i know this was the case with my bmw cpo and geico mechanical breakdown coverage. might wanna check that so you arent unpleasantly surprised later.
#74
I noticed the car following grooves in the road on the way back from picking it up on Long Island. When I got home, I found the tire pressures were all over the place, so I filled them up, and headed out last night. Car still tends to fight me, like it wants to go it's own way when it hits bumps or channels in the road.
The rear tires are new, the fronts are a little worn. 18"ers
Is this just sensitive steering that I am not used to, or do I have a problem?
-td
#75
Originally Posted by td873
I didn't read the trail, so this might be a double post: sounds like you might have a toe-out alignment. Get your tires aligned with a slight toe in, and you should be right as rain. Oh and upgrade your suspension. And get a supercharger. But that's everything you'll need. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
-td
-td
As for a CPO, I would have if I could have. But there are no Porsche dealers near enough to me to build a relationship with, and the one that is kinda near has not had the best write ups here.
