Went for a drive last night-car tramlines a lot - normal?
I'm guessing you have the 18's? It depends what you're used to. Coming from my MB (205/70-14) to my parents' 996 with 18's it feels like a ton of tramlining. Coming from my brother's BMW (225/55-16) the 996 still has more but not nearly as strong a contrast.
Originally Posted by evansaero
Cost at my dealer down here was $105
Only a dealer or race shop will be able to do it. A reg alignment shop will not be able to do it. You should be in and out within 2 hours
Originally Posted by DCP
Huh? I had mine aligned at an alignment shop.
Firestone, Tire America, the local Euro Shop that works on Porsches and also the race shop that only works on Porsches did not have the equipment to do the alignment.
I'm in Richmond, Va and don't know about local shop around you. After talking to all of the above I was told every time that the only place that has the right equipment was the dealer or race shop. The Race shop down here does it by hand and it takes most of the day doing it that way.
I will say one of a reg alignment shops attached to a gas station did say he could do it but he couldn't get me done in the time I needed so I called all the others above and now I believe the alignment shop was going to screw it up if I had gone with them. Hell Even Firestone said they don't have the right equipment.
Originally Posted by AndyK
Wow, your dealer is cheap ($50 an hour)! In my area, 2 hours of dealer work would cost me way more.
My mechanic says to bring the car to STS - they have a new laser machine that will work on 996's. I thought STS was for Hondas--no? Is it better to pay another $100 to have the dealer do it, or am I being too ****?
How do you define "fights you" - i think everyone is talking about different things.
If you take your hands off the wheel and the car tracks straight, it is not an alighment issue. If the car goes to left or right, get an alignment.
But if you are talking about how if the highway dips slighly (say 10 deg angle to the left) and you keep the steering wheel to the right slightly (Like .1 to .25 of an inch) , that is normal for the car.
The steering is sharp, not mushy - it is very unforgiving.
STS use the latest wheel alignent technology supplied by Hunter and should be fine
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Depending on how quick it jerks one way or other, and how quickly it resets to 0, it sounds totally normal.
I had it with my 01 and 03...
I'm sure most modern alignment shops have the equipment to work on a 996 but they may not want the hassle. There really isn't that much to it. I align my race cars (same basic suspension) in my garage. I'll probably do my street car next time to. It's actually sort of fun.
As for your car wandering a bit, remember, a stable car is a slow car. A car that wants to go straight doesn't want to turn.
Jim
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Jim
