filling the tank
Early models do not I believe have the electrically operated valve that sticks shut when fuse E6 blows - so early vehicle fuel filling issues can be related to other factors.
There is a one way flapper type valve at the junction of the filler neck and the tank. This is to allow gas in but not out.
This flap can stick, and certainly on the early 986 there were tubes in the tank behind the valve that could slip down preventing the flapper valve from opening allowing only the filler neck to fill up then slowly seeping gas past the valve.
On the 986, pre MY 01 cars had a mechanical flap, MY 01 onwards had the electrical version with the E6 fuse issue. (orvr)
Probably the same for 996?
The mechanical issue can come and go - the later electrical issue stays until the E6 fuse is changed and the short by the steering column is fixed.
Chris.
Chris.
Thanks for all the answers.
I read each one and checked through all the links. I will be paying close attention to all the symptoms desribed and try to narrow it in. Unfortunately, with that small tank, it has to be filled up alot. So I will quickly have many chances to try different methods.
On a side note - all the knowledge that is on this list is remarkable! I feel really fortunate to have found this site and not only get great answers, but to get them from those feeling the same passion for the vehicle as I do. There are others out there as 'hooked' as I am. Nice.
I've had a similar problem (and am new to Porsche and the Forum). I've had "some" luck simply pulling the gas nozzle back so it's barely in the car. You have to watch it carefully, as it tends to defeat the overflow protection. If you come up with an answer, I'd love to know what you found. I'm leaving in a few days to drive 101 down the coast from Washington to San Diego, and REALLY don't want to spend half of each day battling the gas pump. Never posted before, so here goes...
So far I have just adjusted the nozzle to be barely in. As snowmoose stated this defeats the overflow protection so you have to listen and watch pretty carefully.
Still working on it, but sure wish I was on that drive down 101 from WA to San Diego.
Here in upstate NY it will snow and rain for the next 5 days.
eric
Originally Posted by PJunkie
I am sure this question proves my status as a newbie but here goes.
Has anyone had difficulty getting the fuel tank to fill up? I have tried a number of angles and the nozzle on every gas pump automatically shuts nearly every gallon or half gallon. Eventually it fills up, but it is a struggle.
I have tried it myself in NY as well as while passing through NJ where it is mandatory full service. The attendants there have had trouble too.
Is it my tank (BTW-way too small)? Or the angle going in just has to be correctly found? Or is there something like a secret handshake that no one has told me yet?
tiny bit of help please.
Almost made it to San Diego. Did cut off 101 to 1, running down the coast from Northern Mendocino County on south. WELL worth the time. Probably the best drive I've ever had. Nice on the weekdays when you don't have too many stupid people on the road. Near 80 today, so sorry to hear about the snow!
As for the fuel issue, it's all over the board. Sometimes on "E", shortly after the light comes on, I can get 14 gallons in, but its ranged from 10 to 12 usually. And, gas is EXPENSIVE in CA!
snowmoose- sounds like a great ride. i'll be driving down to Atlanta this summer from NY. really looking forward to that much time in the car. the weather has finally cleared here and driving around is awesome. sometimes I'm just riding alone take a corner and just burst out laughing...great cars...huh.
as for the gas thing, I have been tring different angles and depths. straight in midway seems to be the best. also, listen to the fill. you should be able to know almost the exact moment when it is full.
