996 Forum 1999-2005
Tail-light wiring... bet nobody knows the answer to this...
Old 04-02-2007 | 03:22 PM
BruceP's Avatar
BruceP
Default Tail-light wiring... bet nobody knows the answer to this...
In the taillight assembly, there's a socket for the side marker light. In mine, the wire leading into the socket seems to have been pinched so that current only gets to the lamp intermittently.
The bulb sits in a socket, the back of which appears to be sealed somehow. The only 'official' way to fix it is a new harness for the whole taillight assembly, which is stupid money for such a small problem. So my question: How can you bust open this little socket, maybe snip the broken wire off and just twist everything back together and tape it up? Anybody ever faced this?
Thanks in advance. Sorry to eat bandwidth for such small issue, but lights that don't work are so hillbilly...
Bruce.
Old 04-02-2007 | 05:44 PM
99firehawk's Avatar
99firehawk
I CANT PICTURE WHAT your talking about ?
we are talking the rear light?
Old 04-02-2007 | 05:52 PM
1999Porsche911's Avatar
1999Porsche911
I have to assume that the wire is pinched outside the socket, so I don't see a problem. Cut the wire and reconnect. If it is right at the socket, you can enlarge the entrance for the wire to get to it by using a soldering iron to melt the plastic.
Old 04-02-2007 | 05:57 PM
BruceP's Avatar
BruceP
Yup. The light I have a problem with is the passenger side rear side marker lamp. I was trying to describe the assembly for non-pros.
Imagine you're replacing the bulb. You'd take the taillight assembly out, and then twist and pull the socket thingie for the side marker out of the assembly and pop in the new bulb. Well, it's that socket thingie that's the problem. Holding it in my hand, the bulb will flicker on and off, and my assumption is that it's because a wire has been crimped where it enters the back of the socket.
What I was hoping to do was save myself the cost and hassle of a whole new taillight harness by patching something together. But the socket looks like it's sealed up.
Old 04-02-2007 | 06:01 PM
1999Porsche911
Take your volt meter and test for consistant voltage, movring the wires around while measuring. if you have constant voltage, then your problem is either with the bulb or the contacts. Clean and adjust socket contacts so they make good contact with bolt.
Old 04-02-2007 | 08:04 PM
Mfletch's Avatar
Mfletch
Bruce, I had to fix several similar issues on my car due to an engine fire. If you can find the wires and socket at a salvage yard, you can cut the wires a few inches away from the socket and splice the junkyard wires & socket onto the existing one. This should only cost you a couple of dollars.
Try Silver Star Recycling in Rancho Cordova California. I wouldn't bother with LA Auto Dismantlers...they will try to sell you the entire wiring harness for the car for a couple thousand dollars (ask me how I know). My favorite method of splicing wires is to solder them and then shrink wrap them. Good luck.
Old 04-02-2007 | 08:07 PM
BruceP's Avatar
BruceP
Yikes!
Dealer quoted me about $200 for the harness. Still seemed like a lot for an essentially ornamental light problem, though. Dismantler is a good idea. I assume I could ping these guys from here and have the part shipped... Rancho Cordova is a long way from Toronto.
Old 04-03-2007 | 01:47 PM
Edgy01's Avatar
Edgy01
Poseur
A picture goes a long way...
Old 04-03-2007 | 02:07 PM
BruceP's Avatar
BruceP
Yeah, I know. But... underground parking, no camera with flash. Sorry...
Old 04-03-2007 | 02:45 PM
wwest's Avatar
wwest
Give my an address (via strobedata.com) and I'll send an almost complete harness, FREE, certain to include the socket you need.
Old 04-03-2007 | 02:53 PM
BruceP's Avatar
BruceP
That's a fantastic offer, thank you. Message sent!
Old 04-03-2007 | 03:20 PM
Einstein's Avatar
Einstein
pics, pics pics please!
Old 04-03-2007 | 11:16 PM
Chuck Jones's Avatar
Chuck Jones
Wwest: Guys like you make this forum what it is...helpful, informative, and "staffed" with a great bunch of guys. Nice of you to offer your harness to Bruce. Saved him a bunch of $$. Chuck
Old 04-03-2007 | 11:41 PM
BruceP's Avatar
BruceP
True dat.
I hope I can be useful to someone around here one of these days. Still prolly only in the tenth percentile of Porsche smartness...
Quick Reply: Tail-light wiring... bet nobody knows the answer to this...
