Track car advice
Originally Posted by SleepRM3
The '99 is apparently the lightest 996 (light is always a good thing for track
). Hopefully the usual track stars (JimB, RayS, Paul) will chime in?
). Hopefully the usual track stars (JimB, RayS, Paul) will chime in?There are some on this board that do not think these differences are substantial. However in my experience, the power and chassis revisions can be easily felt on a back to back test drive.
No reason to take my word (or anyone elses word) for it. Head over to a few local Porsche dealers and spend a day doing some test drives.
Good luck!!
Well--if LSD is not the limiting factor, then I should just save up for a 996 Mark II? The 2004 40th Annie is looking better and better, but wow are they high right now! I wasn't aware that non-40th anniversary Mark II 996es could have the X51 power package as an option?
Originally Posted by Ray S
The '99 is the lightest, but it is also the least powerful. If you were going to turn a 996 into a racecar, I'd look for the lightest optioned (i.e. lightest) Mk II you can find with the X51 powerkit. The '99's are great cars, but they are at a hp disadvantage vs. the Mk II's (especially x51 cars). Also don't forget the Mk II's have improved cooling, a stiffer chassis, improved aerodynamics (less lift), and improved high g oiling (revised baffles).
Good luck!!
Good luck!!
It can be added at any time (to a Mk II), but get out your wallet and prepare to cry it is very expensive.
What are your plans for the car? DE's, Club Racing, SCCA, other??
How often will you track it (track days/year)?? Will it also be a street car (or track only)?
My prospective Porsche 996 will be a nice road car that would be tracked 3 to 4 times per season.
The x51 was an option on all Mk II's. Unfortunately it is about as rare as the LSD option on '99's.
Originally Posted by Bob Rouleau
From experience, any 996 is fine at the track. Earlier models had a limited slip available (hard to find though) but the new cars have more power. The 99 through 2001 also had some oil starvation problems as I recall. I'd aim for a 2004 or newer. You will have a hard time finding one without a sun roof. Don't worry about it. You'll never notice the difference driving except for headroom. A seat will fix that.
A GT3 seat will cure your headroom problems. There are several guys 6'5" driving 996's around Calabogie and Tremblant now. The Recaro might do too. All cars from 2000 on had E-gas, and the newer ones are far less intrusive. Same goes for PSM, on 2006 and on you can get pretty far out of shape before it intervenes. When it intervenes it is because you messed up.
In your shoes, I'd look for a car that had been well maintained as opposed to trying to find a rare non-sunroof or LSD equipped version.
With a rear facing child seat your 996 will probably be a 3 seater since no adult would be comfortable in front since the seat has to be pushed way forward to provide the room needed.
Any of the Porsche models is a blast on the track - exception the Cayenne of course. If you are new to the DE game, don't worry about the model, you will have a ball with any of them. If you get the track bug seriously then you want something like a GT3 <grin>.
Best,
Best,
FWIW: I was on the track last week and could only detect a minor difference between my 99 and an 03 down the straight away. This is after countless sessions and noting whenever I met up with him on the main straight. There was an ever so slight advantage to the car with the 3.6 but essentially felt like we were staying dead even. Both cars were stock (only thing I have is an exhaust and he had an intake)
Edit: not an attempt to defend the 99s or anything. At first when I noticed it my thought was wow I need to find out what mods this guy did. He has a little bit more pull. I was pleased when I found out it was a 3.6 at work !
If you are talking purely stock cars, I think the differences betweeen 99-01 and 02+ are negligible (assuming no X51, etc . . .)
I disagree.
The 3.6 is definitely faster than the 3.4 with noticible differences.
The 3.6 chasis is stiffer and signicantly better and you should be albe to tell in your first turn on a track.
I actually bought PSS-9 because Darren let me drive his 3.6 with PSS-9 at Watkins Glen. I was really impress with the turn in of the car and I thought it was PSS-9 that makes the difference. It was not!
I was wrong because my 3.4 with PSS-9 does not turn in like that. Since then I have had a couple of students with bone stock 3.6. They all turn in really nice on the track in stock form.
My $.2
Kam
My $.2
Kam
TD,
Come on spare me the noob answer
. I know when I am catching or losing someone through a corner.
My point for everyone was that when both cars were at roughly the same speed the 3.6 has a slight advantage but not much over the 3.4. Only reason to post is that a lot of people think there is a huge difference between the power of the two cars but in reality it is minimal and the weight difference almost negate it.
The corners are where I was gaining on this particular car but once I got to the straight it was a match shift for shift all the way down the straight with him slightly edging away.
. I know when I am catching or losing someone through a corner. My point for everyone was that when both cars were at roughly the same speed the 3.6 has a slight advantage but not much over the 3.4. Only reason to post is that a lot of people think there is a huge difference between the power of the two cars but in reality it is minimal and the weight difference almost negate it.
Originally Posted by ZBlue996Kam
I disagree.
My $.2
Kam
My $.2
Kam
I think the PSS9s are a good choice for a DD that gets taken on the track for a few DEs. I think they are a bad choice for a track car.
The power to weight ratios remained the same for 3.4 and 3.6, so how could it really make that much of a difference in acceleration? I find that most of the difference is really attributable to corner exit speed. Of course, I am talking purely stock here, so once the cars start getting mods, hard to tell the ultimate impact.
TD,
The only time you can really know that a car is truly pulling you is when the acceleration differential is really large, which it is not between the 3.4 v. 3.6. For cars that have roughly the same power/weight ratio, you would have to get next to each other on the straight, and then agree to hit it at some defined point. As you know, that just never happens.
When I first started racing (still noob, so not trying to sound like expert), I found it interesting to see what happens when you go into the first corner of the race -- imagine 80 cars trying to go through T1 at VIR at the same time. This accordion effect makes it seem like other spec cars are faster than yours leaving the corner if they get on the gas sooner than you do (which is normal since they are in front of you). I found that I could do pretty well if I could force myself to get back on the gas "before" I "should." This would let me get a slight jump (or at least be back on the gas at the same time) over the cars in front of me.
So, I wasn't trying to be condescending, I was just pointing out that the car in front of you during a DE situation will nearly always seem like it is pulling you (even more so if they are slow through the corners) because they get a jump on you exiting the corners. The only way to fight it is to get a run on them or get on the gas so early that you nearly punt/pass them at corner track out.
In any event, it is always more fun for the 3.4 guys to claim that the 3.6 guys have a huge advantage over them
P.S. I know you are saying the differences are neglible. I agree.
TD,
No harm no foul. All in good spirit. I agree that the 3.4 and 3.6 cars are very very close based on my experience.
Now others may disagree as they are allowed to and I am sure we will hear some more opinions. time for some...
